Question about Optics
What kind of scope would be good for my 308 axis rifle?
What would be a good scope for this gun?
Posted by donnie trevors on
Mark Carswell
Redfield and Vortex brands make good entry level scopes with good clarity, durability, features and warranties. If you plan on hunting a scope with a low power around 3-4x and a high power of 9-12x with a bullet drop reticle like the Vortex BDC would be a good choice.
Posted on Jan 16, 2015
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Posted on Nov 26, 2008
Anonymous
  • 99 Answers
SOURCE: RIFLE SCOPE WARRANTY
Here is the contact info for them. ask them :)
Please rate this as fixya :)
Posted on Apr 11, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 05, 2009
Anonymous
  • 12 Answers
SOURCE: how to zero Bushnell 3-9x40 scope rifle
http://www.bushnell.com/products/scopes/riflescopes/doa-riflescopes/
Go to this link & you will be able to zero it. If you lower the angle of telescope you will be targetting farther. vice versa. [email protected]
Posted on Mar 26, 2010
agent91
Ned White
  • 2100 Answers
SOURCE: How to use the BDC on my rifle scope
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. Nikon2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Posted on May 04, 2010
The screw of the front stock got stripped how can i replaced ?
Oversize rethread the mounting point if possible and use a larger screw
Nov 04, 2013 | Beeman Optics
How far will scope be practical to shoot
That all depends on the gun and the shooter. It could be good out to 150 yards with the average shooter, on a good bolt gun. A semi auto like a AR, 150 maybe a bit of a stretch.
Aug 31, 2011 | Nikon Monarch 6-24x50 Sf Matte Bdc...
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
Ilive in indiana and i have a problem with ratcoons . so i set out to buy a good air rifle , i though i had one then i put a bb .177 cal , in my brandnew BEEMAN air gun ,the the bb feel out the barel ......
Are you sure its a bb gun and not a pellet gun? Usually bb guns have a magnet on the bolt, that keep the bbs from falling out. Pellets don't roll so the won't roll out the barrell.
Mar 03, 2011 | Beeman 1024 Takedown Rifle, Scope, Rings &...
I purchased a Fujinon 3.5-10X50 rifle scope a few years ago and mounted it on a Remington 7 MM Mag. I am unable to pull a group less than 12 inches at 200 yards and have not been able too since installing...
It is most likely the mounts not the scope. I would just install it on the new gun and check it there. Most times a scope that wanders is the mounts. One thing with big scope is they need to be tight or the recoil will move it in the mounts. Next due to being tight when the gun heats up it can and will tweak the scope in the mounts enough to move your center. Try it in your other gun, try 3 shot groups and let the gun cool. Recheck your center. If it is good with a cold gun all is well. If it moves from one day to the next it is the mounts. If you count the clicks to recenter, come back the next day and move it the same clicks, it is the mounts. If it is all over the place, day after day it is the scope.
Jan 21, 2011 | Fuji non 4-12x42mm Rifle Scope
Adjustment
you have a gun mount problem its not a scope problem ,,,the scope mount is not a good fit to the gun and is off set to the barrel,,,
set the scope to center of its ajustment and then "pack out the scope with a bit of old 35mm film till you get it close to were you need it to hit then do the last bit of ajustment on the turrets,,this works for lift and windage
Jul 06, 2010 | Barska Optics BARSKA 1040X50 AO Varmint...
How to zero Bushnell 3-9x40 scope rifle
this is a good guide:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
May 15, 2010 | Bushnell 3-9x40 Mattee R/g Crosshairs...
The paint has been chaffed off from being pulled in and out of a gun bag. What product can I use to recoat my scope
You can rattle can it, but the spray nozzle is course compared to the factory finish. You might even try a can of gun blue, walmart has it, g96 brand works good, rub it on then spray it with wd40 to oi it up and polish it.Or you can check out this guy on ebay,
Broken Scope Crosshair Repair
Mar 14, 2010 | Tasco RIMFIRE SCOPES BLACK GLOSS...
My elevation and windage adjustments aren't moving my scope. I shot 4 times and my group is 1 inch. Problem is I adjusted my scope between all 4 shots. I'm consistently shooting 7 inches high and 3 inches...
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
Nov 23, 2009 | BSA 3-9x40 Deer Hunter Riflescope
Crosshairs have turned anti clockwise
Probably the rings on the scope have loosened and the body of the scope has pivoted to the left. To correct it, you need to put the gun in a gun vise or in a cleaning stand to hold the gun straight. Then you would need to confirm that the scope has tilted to the left. You will have to loosen up the rings and turn the scope so that it is upright. The best way to make sure is to use a scope level. Lay the scope level on top of the scope turrent to confirm that the top of the scope is level. Sighting thru the scope you should be able to confirm that the cross hairs of the scope are now level. Carefully re-tighten the scope rings to the manufacturers torque recommendations. Then the scope should operate properly.
Aug 28, 2009 | Optics
Optics Logo
102 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
