Question about Sewing Machines
How do I get the bobbin to thread after I put it back in the holder.
I have tried all kinds of ways to make it pick up the thread from the bobbin
Posted by clayton howard jr on
Frank James
    New Friend:
  • 3 Answers
Do you have the bobbin holder threaded right? You have to put the bobbin into the holder and follow the thread path, then pull it up to the top and turn the needle by hand until the thread picks up the bobbin thread. then pull both threads up and to the back then slide your bobbin plate back into the machine and you are ready to sew. Hopes this helps. wish I could draw you a picture.
Posted on Jan 10, 2015
My Sunbeam SB1818 needle will not pick up bobbin thread so I can sew what do I do
make sure tat there about 6" of bobbin thread hanging out after you put the bobbin back in the bobbin holder
increase the needle thread tension up more thread tension should be a slight drag as you pull the thread out to thread the needle
Oct 30, 2016 | Sewing Machines
I can't seem to get the bobbin holder in there correctly to get the machine to sew properly.
While I know it can only go in 1 of two ways, maybe the problem isn't in how the bobbin is in, maybe it is the route of the thread.
My assumption is you don't seem to pick up the bobbin thread and it bunches. If so the carefully follow the thread to needle you may have by passed the place you put that thread so it maintains tension.
Check that carefully, sometimes that gets overlooked.
Jan 16, 2015 | Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
Threaded correctly bobbin threaded and inserted correctly...threead will not pick up and pull throughbobbin thread
Have you got the needle in the right way and is it put in all the way up the holder? Some needles are longer than others and this can also cause that problem. The bobbin thread should double back on itself coming out of the holder.
Feb 18, 2011 | Singer Confidence 7463 Computerized Sewing...
The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Jan 22, 2010 | Elna 2007 Mechanical Sewing Machine
My machine will not pick up the bobbin thread
how long have you had the machine?
I don't see what kind of machine you have?
does the bobbin drop in from the top, side, bottom?
email me at
[email protected]
tell me what kind of machine and model number you have
I'll see if I can help
Sep 02, 2009 | As Seen On TV Sewing Machines
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Dec 27, 2006 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
98 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
