Question about GE Refrigerators
Can I purchase a new door Gasket for a GE compact refrigerator Model number WMR04GAVABB?
Model number WMR04GAVABB Need replacement door gasket
Posted by Stein H Innvaer on
kejelj
    New Friend:
  • 8 Answers
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
Model number ps 297192. How do I replace the freezer door gasket?
it may be best to have a technician or a door seal specialist do the job
some are screwed in and others are glued in behind the plastic door insert.
Jun 26, 2015 | GE Profile PSW26P Stainless Steel Side by...
PARTS NUMBER
Hello Jerry;
My name is Peter. I am a retired field service refrigeration technician.
You need to provide a model number for me to give you the gasket part number and price. The model number is on a label in your fresh food section on the upper side wall.
You have a bottom freezer, Right? These bottom freezer drawers are had to seal all of the time. They can get off track and not seal properly. It is not uncommon for them to ice up around the door gasket.
Lets try this first:
1.) Clean the gasket.
2.) With a hair dryer and a kitchen spatula, Heat the gasket while pulling gentle out on the gasket, to expand the gasket.
3.) Run a piece of paper between the gasket and the freezer front. If you can do this, then you still do not have a solid seal.
Feb 25, 2015 | Freezers
Samsung SLR550DW - replace the freezer door gasket
Hello Kev;
The number that you have provided is your general manual number, which is common to several different models.
Your model number is on the upper inside wall, on a label in your fresh food section.
I have replace many a gasket. Post your model number and I will be glad to help you.
Dec 23, 2014 | Samsung Refrigerators
Gasker
On this model I will give you both gasket numbers as you didn't specify which one you needed. Freezer door part number 7010574, Refer Door 7010584. I verified that these numbers will match your serial number as you left it for me. I hope this helps you, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 16, 2014 | Sub-Zero Refrigerators
Need a door gasket for a 1969 coldspot chest freezer dont know model no
On all refrigerators there is an identification tag that gives the model number. Without the model number you won't be able to find the correct door gasket.
Tips for finding your unique model number
  • Look for your model sticker, tag or plate.
  • Include every digit in the model number, even if some are sized or styled differently.
  • Kenmore and Craftsman model numbers typically have three digits separated by a period.
Examples:
Jul 03, 2011 | General Freezers
Seal on door came off where can I get a new one?
Replacement door gaskets can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three websites also have exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If the model is correct, the gasket is listed as item 3 under the "Tub and Frame" parts list on most of the parts listings. The part number will depend upon the model number. The model number you provided is not complete.
If you need instructions on how to replace most common dishwasher gaskets, the following link can give you some guidance:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
Most dishwasher gaskets are the press in place variety. However, some require gluing in place with a special rubber cement. The glue will come with the installation kit.
If you have any questions, please post back with your complete model number (located around the door edge frame, or door opening). I hope you find this information helpful.
Dec 18, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire dishwasher bottom door gasket replacement
thank you so much for this information it was a god send
Oct 07, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Vish Iyer
Vish Iyer
gbob59
