unplug from wall check contacts at motor and pcb/ timer plug back in see if that works motor pulls a lot of juice look for a burnt contacts or connections. motor may be thermally fused .dont just bypass find the reason why thermal fuse failed
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Hi just read your posting.Now when is the machine noisy?Is it when the machine pumps out the water or when the bowl spins.Sorry to ask you this but please be accurate when you reply to this question.The reason being is that if it is noisy when it pumps the water it could be your pump but if it is noisy when the bowl turns for the spin then the problem will be your bearings and seals.Select a spin cycle and push start,is it noisy as soon as you push the start button?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty
costly repair on most models, sorry
oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
