Question about Polaroid Televison & Video
So I have a Polaroid tv and when I turn it on it show the Polaroid sign then it goes black but the sound is still working. Is the electrical box broken.
Posted by Aaron Hernandez on
mbarre
  • 937 Answers
If it powers up to the initial display then the power board is likely good. Maybe the tuner...? there are a couple of Polaroid vids, if this one not on target, peruse a few on youtube...
Posted on Jan 09, 2015
5 Related Answers
Anonymous
SOURCE: 42' polaroid tv wont show screen still
it is a manufacturing defect. Mine had it. My advice is to never buy polaroid tvs. but anyway, here is a link on how to fix the problem...
http://www.fixya.com/support/p443928-polaroid_flm_3732_television/tips
Posted on Dec 29, 2008
romsky79
rommel dadulla
  • 822 Answers
SOURCE: screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
Posted on May 05, 2009
jd0770
  • 6 Answers
SOURCE: Screen goes black after couple seconds on my Polaroid 42" LCD
I had a TLX-4240B 42" Polaroid LCD TV and the screen would go black after about 10 minutes. There was still sound. I removed the two covers exposing the circuit boards behind the TV. I powered up the TV and waited for the screen to go black (I was going to start trying to pinpoint where the issue was with my trusting meter) then noticed a red light would come on when the screen would go black. there were 4 mini switches right above the red light. I switched the one that said burn and the TV has been working great since. good luck and let me know!
Posted on Aug 05, 2009
Anonymous
SOURCE: 42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Posted on Aug 22, 2009
RNS-Systems
RNSeStore.com
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv blacked out no sound either, but power light comes on and off
just talked to polaroid because mine did the same thing......... power light is on and when you first power it on..... the polaroid screen appears for a second and then goes out............. they told me it sound like the control box and would cost me 225.00 to have it fixed............. does anyone know how to get a control box from some one other than polaroid....
my tv is TDA-03211C 32 inch with built in DVD
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Jun 12, 2009 | Polaroid FLM-2632 Television
Screen goes dark after few minutes
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
Poloaroid 42' LCD tv wont come on
well if you get a screen that shows the polaroid logo with a bright ble screen then goes to black...some q's to answer for me ....does the power indicator on the lower right front of the tv go red,stays blue,or goes out completly??
Dec 13, 2008 | Televison & Video
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
