This normally implies a functional issue with the machine. Try an error reset first in case the unit was turned on\off or lost power recently: To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. If that doesn't work you will need to test some components - are you a repair tech or have electronic experience if not you might want to contact a service center to avoid hurting the copier or yourself. If you do have experience take a look at page 6-10P http://diagramasde.com/diagramas/otros2/IR2200_2.PDF and Error Codes Canon iR2200 Warning!
If you are not familiar with electronics, do not attempt to repair!
There is a risk of fatal electrical shock! Instead, contact the nearest service center!
