HP LaserJet 1020 Printer Logo
DR JOHN Posted on Jan 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RESET PRINT COUNT HP 1020 PRINTER
How do I do a cold reset on HP 1020 printer? there is no "Go" button to hold down on this model. the only button is the on-off switch.
Mark Schmit
Level 3:
  • HP Master 1,915 Answers
  • Posted on Jan 09, 2015
Mark Schmit
HP Master
Level 3:
Answers
1915
Questions
0
Helped
753908
Points
7967
A cold reset should not reset the print count. Those are usually stored in non-volatile memory to prevent scammers from selling used products as new.
How to cold reset
http://www.ehow.com/how_8337650_do-restart-color-laserjet-3600n.html
Instructions <:section>
    • 1 Turn the printericon1.png on and look for the control panel display to count the memory. When the memory count begins press and hold the green "select" button located on the front of the printer. When all three of the front control panels LED are lit release the "select" button.
    • 2 Press the "Down Arrow" once when you see the "Select Language" display. Press the "Select" button until your controlicon1.png displays "Cold Reset."
    • 3 Press the "Select" button and your printer will initialize a cold reset.
Password in motherboard m5035
Cold reset requires no password. Go to the machine and turn it off. Power it on and when the memory count starts, hold down the 6 button on the keypad. Hold until all three leds turn on and stay on. Release the 6 button, press the 3 button until display reads "cold reset", press 6 once more and printer will restart.
2helpful
2answers
Hp 1020 printer total page count information
Hi, what operating system are you using? In Windows XP you can view the page count by doing the following:
- Go to the printer's Properties window (click the Start button, go to the Control Panel and click on Printers and Faxes, right click on the printer and choose Properties).
- On the General tab, click Preferences.
- On the Basics tab, click About.
You can see the page count in the About window, toward the bottom.
For page count or configuration page instructions on other printers and copiers, check out the How to Print Configuration Pages website. Thanks for using FixYa!
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
4 Release the GO button.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
NVRAM initialization
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
To perform NVRAM initialization
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
There is a problem with my leser jet 1020, when ever i am going print a document, paper is coming out but there is no print on it. so kindly tell me what is the exact problem and how to solve...
HP LaserJet 1022 cold reset procedure To cold reset the printer, perform the following steps:
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancel buttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison.
The printer is now reset and ready for use. Back to top HP LaserJet 1018 and 1020 cold reset procedure To cold reset the printer, perform the following:
  2. Power on the printer.
The printer is now reset and ready for use. NOTE: The HP LaserJet 1020 printer is completely initialized at power on. Essential printer information for the printer is stored in the driver software and downloaded to the printer with the print job.
My printer will not print the 1st document. It will come up as an error, and then I cancel that one. Then I RE-PRINT the same document and it works the 2nd time. Any idea's why my printer is doing this?
Do a Cold Reset. This will return the printer to the original factory settings. But first, print out a configuration page so you will have a record of any custom settings you may want to re-enter after the reset. To get the config page, press the Go button and hold until 2 lights begin to flash, then release the button.
To do the Cold Reset:
1) Turn the printer off
2) Turn the printer on. As soon as the memory count starts onn the LCD display, press and hold the SELECT button. Continue holding it until all 3 lights flash once then remain on solid. This can take up to 10-15 seconds.
3) When the message SELECT LANGUAGE appears on the LCD display, press the UP or DOWN button until COLD RESET is displayed.
4) Press SELECT. This will start the Cold Reset process. When it's finished it will continue the power on sequence.
5) Send a job to the printer for a test.
1helpful
2answers
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
4helpful
Change my printer network access password
For an HP Officejet printer:
You can reset the printer definitions taking off the power cord and holding # + 6 buttons (semicomplete reset) or # + 9 (full reset) while connecting power cord again.
For an HP Laserjet printer:
Try logging in with admin as username and leave the password blank.
If not, preform a "cold reset" on the printer which resets parameters back to factory defaults. You want to print off a configuration page first. From the service manual :-
Cold Reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
HP 2200 -
Cold reset:
4. Release GO.
NVRAM Reset:
4. Release GO.
HP 5P & 6P
Cold reset:
Reset the NVRAM:
Laser printer keeps printing hp ads
Please perform the following:
If the printer is connected via network, unplug the network cable and perform cold reset.
Cold reset A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings. Use the following procedure to perform a cold reset.
Then uninstall / delete the previous drivers and install the drivers from the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845555&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-45284-8
k24674
Grand Canyon Tech
Grand Canyon Tech
