Question about Electrolux Dishwashers
Hello JOHN, thanks for your post!
From the information you have provided your Electrolux dishwasher is displaying error code 4. "E4" stands for drying damper which means it could be a potential problem with your damper or the main control. I would recommend performing a reset and that could clear any false error codes. To reset your dishwasher flip the household circuit breaker off for roughly ten minutes. If that does not help correct the issue I would recommend having a professional technician out to properly repair it. Good luck. -Matt
Posted on Jan 15, 2015
Good Afternoon friend, that's a great question!
From my understanding your Electrolux range is displaying a code of "d-o". The code could stand for open door, could be missing a sequence, or a miscommunication within the control panel. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. Hope this information is helpful. -Matt
Hello ericsson1 - Typically error code E08 indicates that the control has detected a stuck or shorted key on user interface board. The wiring between main control board and user interface will need to be check by a certified professional. Depending on the diagnoses either part will need replacing. Contact a professional to move forward accurately.
Hi - Error code E01, typically indicates that a water leak has been detected under the tub. Unit may possibly need a hydraulic kit; however I would suggest contacting a professional to move forward accurately.
