Question about Phoenix Gold Car Audio & Video
My Phoenix Gold TX12D 12" TantrumX Series speaker led is not working. Wat can i do?
Posted by Rajeev Lalay on
4 Related Answers
Anonymous
  • 113 Answers
SOURCE: led light keeps flashing on my phoenix gold amp
if the amp went into protect you need to disconnect all power including ground for at least 20 min to discharge caps inside.
Posted on Aug 08, 2007
jdrrwoods
James wood
  • 82 Answers
SOURCE: wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Posted on Feb 09, 2008
Anonymous
  • 631 Answers
SOURCE: phoenix gold xenon 1200.1
Most of them are NE5532s. There's one NJM13700 also.
Posted on Apr 23, 2008
Kristy Neff
  • 155 Answers
SOURCE: Questions about installing a phoenix gold xenon 200.4 to 2/12"sub
i would always go with audiobahn but that is my opinion,
Posted on May 11, 2010
What size box doe i need for my Phoenix Gold TX12D 12" TantrumX Series?
The box recommendation should be in your manual for the sub. It will tell you optimal box size. and preferd box style. if you dont have a manual you can find one online. or even by writing the company.
Jan 08, 2015 | Phoenix Gold Car Audio & Video
Im trying to find out what 2 15" phoenix gold xs series are worth
they go for about 149.00 each if they are new then very close to new price. if they are used expect about half price.
Jan 05, 2011 | Phoenix Gold Car Audio & Video
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    How to hook up led lights for phoenix gold x10d4 speakers
    THERE ARE 2 WAYS:
    1. (STEADY ON) - RUN THE POWER FROM THE AMP TO THE POSITIVE LED TERMINAL THE NEGATIVE CAN BE RAN FROM THE NEGATIVE SPEAKER TERMINAL.
    2. (INTERMITTENT; COMES ONE EVERY TIME THE BASS HITS) - RUN THE POSITIVE AND NEGATIVE WIRES FROM THE + AND - TERMINALS TO THE POSITIVE AND NEGATIVE TERMINALS OF THE LED LIGHTS.
    LET ME KNOW IF THIS WORKS FOR YOU -- [email protected]
    Mar 15, 2009 | Phoenix Gold Xenon X10D4 - 10" D4...
    Wiring my subs to my amp
    Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
    Wiring diagram
    The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
    The Octane R10 is a Single Voice Coil or SVC.
    AMP+ to Sub+
    Amp- to Sub -
    Use 12 guage wire.
    Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
    Car Audio & Video Logo
    79 people viewed this question
    Top Phoenix Gold Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
