Question about Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Posted by Samantha Domnick on
Sys Admin
  • 73 Answers
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Posted on Jan 08, 2015
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
Lost charger to Asus transformer pad tf300t was wondering if I could charge it through the USB port located on the side of the docking station
No, that is not possible. That's because you need an ASUS-specific charging cable to charge either the tablet or the dock/keyboard (or the docked combination of the two). You can however use any charger with a USB-port that outputs at least 2 Amperes. So you need to buy a new ASUS charging cable (and a suitable charger, if you don't have one already)
Mar 06, 2015 | ASUS Tablets & eReaders
I bought two irulu tablets but the both broke in the same exact spot, in the charging port. the pin broke out and i cant charge them now. Is this a flaw with all irulu tablets or just the two I bought
I would definitely follow your friends advice. If they are under warranty, you should be able to get them fixed. If the battery can come out of the tablet, you can use a universal charger to charge the batter, but I am assuming it doesn't.
If you know how to solder, then you could replace the port yourself, but this is risky, so getting pro help is the best bet.
Feb 14, 2015 | Tablets & eReaders
Why won't my ipad wont turn on or charge
When you plug the cord into the iPad do you get a charging icon?
Jun 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Dragon Touch Android tablet. How can I replace a broken power button?
I bearly got my dragon touch and then my power button broke?
Jan 26, 2014 | Tablets & eReaders
Irulu tablet wont charge
These are the videos which will help you why tablet is not getting charged and solution to overcome
Try to use USB and charge it with it
and then after 10 min try to start the tablet
Jan 16, 2014 | Irulu 7 Touch
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
473 people viewed this question
Top Irulu Tablets & eReaders Experts
gbob59
Harrie
bobalix
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
