Question about PfaFF Sewing Machines
I was oiling my 1473 pfaff was working fine before i oiled it now the display blinks on then off and stayed off like others have stated but there is no fuse becauseit has 120volt for power
Tried other power cord took top off checked to see if any electrical could of came apart all looked o.k.
Posted by glen edwards on
MissFixIt828
    New Friend:
  • 70 Answers
Unfortunately you probably need a new board and the parts are no longer available.
Posted on Jan 08, 2015
How to take apart a singer sewhandy 50d to rewire it?
These machines are not user serviceable, no parts will be available to the general public.
Please have a trained service technician look at your machine. electrical issues and mechanisms do require service from time to time, especially with heavy use. If you use your machine frequently, have it cleaned and adjusted based on your use levels.
Cheers,
Embroidery Services
San Diego, CA
Jun 16, 2016 | Singer Sewing Machines
Is it possible to change the fuse in a sewing machine?
the only fuses ive ever seen inside a sewing machine was located inside the foot switch assembly and ive taken apart a few dozen now , but now ive seen quite a few broken power cords and sockets in that few dozen , seems the power cords sure take a beating on these ?
Jan 14, 2016 | Sewing Machines
I just plugged in my sewing machine into a new apartments socket. This machine has always worked. I smelled a strange odor, and went to get scissors. When I returned the machine was completely dead. Did...
1. Have you tried it in another socket? Check the light bulb to ensure it isn't rubbing against something (smell).
2. After you try the machine in a new socket make sure the on/off switch is set to on. Is the bulb lit? Replace it if not. Also, check the outlet with something else electrical to make sure it is working.
3. Make sure the cord is attached securely to the machine.
4. If these checks hasn't worked your next move is to go to your repair shop.
Mar 20, 2015 | Sewing Machines
No power for my singer 7258
Could you please clarify this issue? Is your power cord missing, or you have it and the machine doesn't turn on?
I just took a look at the user's manual for your machine, and your power cord is a standard two-prong polarized laptop cord--you can buy it at any computer store. You may have similar cords around the house on, for instance, your printers. Your first step is trying another cord--that's generally the problem.
If it still doesn't go on, I'm afraid that you'll have to have a technician take a look at it--it could be anything from a blown fuse, to a defective motherboard, to a bad motor.
Feb 18, 2015 | Singer 7258 Sewing Machine
I am looking for a power cord and cable for a XR36, Brother Machine
your voltage is 220 vac and 50 hz down there and what type of electric plugs do you use but the xr 36 does not exist on brothers web site there is a xr35 and xr37?
Oct 13, 2014 | Sewing Machines
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
The wheel is completely stck and will not turn. I was sewing and everything was fine and then all of sudden this happened...i took apart and cleaned....can't figure it out.
Check the top shaft bearings. Have similar problem on another computerized model. Top right bearing was completely stuck. Using Liquid Wrench to unfreeze it. Afterwards use sintered bearing oil like Tri-Flow to lubricate bearing.
Mar 11, 2011 | Brother SE-270D Computerized Sewing...
My machine is not getting any power. I took my machine to a class yesterday. It worked fine but when I plugged it in here at home last night, nothing happened. I checked the outlet with a lamp and the...
it is possible the power cord has gone out,,or the power cord receptacle has gone out
i've been working on a sewing machine that they connected the power cord & disconnected it so much that they pushed the pins out of there sockets
or the on/ off switch has gone out
Nov 19, 2010 | Brother Sewing Machines
Lost Electric cord and pedal
I thought mine was also lost until I looked in the hidden compartment at the top on the back side. Just a suggestion
Feb 23, 2008 | Euro-Pro 416 Mechanical Sewing Machine
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Asmodius
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
