Question about Radio Communications
How do I get the speaker to pair?
Will not pair. Voice says it is paired, shows up paired on the phone, but is not. There is no sound. Speaker works- I can use remote 'in', but I want to use Bluetooth. Thanks for your help. Ted
  • 937 Answers
Ted,
what are you pairing the headset with? make & model
Posted on Jan 08, 2015
The speaker paired with my phone for talking won't play music!
Check the properties of the bluetooth device on your phone. Most newer devices have the ability to enable/disable the bluetooth speakers ability to play either media or voice. This is a good place to start. If that does not work, verify that the bluetooth speaker works as you expect it to on another phone.
Jul 06, 2016 | Cell Phones
What am I doing wrong
You did not mention pairing it. Remember that bluetooth speakers need to be paired with your IPhone. Consult your speakers documentation for steps to pair the device to your phone.
Mar 27, 2015 | Apple iPhone Smartphone
How do i pair my phone to play on my insignia speaker?
1. Press and hold the button to put the speaker in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the speaker.
2. Turn on Bluetooth on the phone and tap on Scan. The phone will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the speaker's name, tap on the name to pair with the phone. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the speaker will turn to a steady blue and you will see 'Connect' on the phone. Tap on Connect and then you will see Connected on the phone. Your phone and the speaker are now connected.
The steps above should be detailed in the set up guide that came with the speaker. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the phone to the speaker, a "get to know you" procedure. After that, you just need to connect the two.
Nov 15, 2014 | Insignia NS-BT400 Portable MP3 Speaker w/...
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
Iwave bluetooth speaker makes a "busy call" sound
This might be the problem with pairing. Just try to reset the Bluetooth Speaker and pair with it newly. It may help you. It worked for my SUPERTOOTH Speaker. Hope it helps.
Jun 09, 2014 | Macally iWave Computer Speakers
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
My jam speaker is paired with my galaxy tab 2. I have been using it To listen to music and it has been working. I turned the speaker of and a couple hours later went to put it on again and when I did the...
I have a similar device. If you didn't un-pair it or you moved the speaker too far away or didn't play music for over 5 minutes it shuts down. It may show that it is paired but doesn't play on the speaker. You have to un-pair and re-pair the speaker for it to work again.
Nov 09, 2013 | Tablets & eReaders
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
Earpiece not working after hooking it up with a bluetooth speaker
Go to Bluetooth settings and turn on Bluetooth.
The paired devices will be shown.
Delete paired device or unpair device .
This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
Mar 28, 2017 | Motorola Mobility ROKR E8 Cellular Phone
Radio Communications Logo
152 people viewed this question
Top Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
