Sorry about that Jack. If you have good power coming in, just try and trace that - through switches & the control logic. If the power is making it to the heating element and it isn't heating... Not sure if the element is replaceable.Sorry about that Jack. If you have good power coming in, just try and trace that - through switches & the control logic. If the power is making it to the heating element and it isn't heating... Not sure if the element is replaceable.
You can't post conmments that contain an email address.
E1 is an error code that may be displayed on a Lifesmart infrared heater. It typically indicates a problem with the heater's thermostat or temperature sensor.
If you see the E1 error code on your Lifesmart infrared heater, it is recommended that you try the following troubleshooting steps:
Check the heater's power cord and ensure that it is securely plugged into a working outlet.
Check the heater's thermostat and ensure that it is set to the correct temperature.
Check the heater's air filter and ensure that it is clean and free of debris.
Check the heater's temperature sensor and ensure that it is properly connected to the heater.
If the above steps do not resolve the issue, it is recommended that you consult the heater's owner's manual or contact Lifesmart customer support for further assistance.
It is important to note that if the E1 error code persists, it is possible that the heater may be malfunctioning and may need to be repaired or replaced.
I have found several user manuals for Lifesmart heaters online and have looked through them.
None of the manuals I looked through mention reset buttons.
You have not stated the model number for your Lifesmart heater. If you choose Comment and type the model number in the Comment box, perhaps I can find the right manual for your heater and give you the link to download a copy of the manual.
Is your problem that while using your heater is suddenly turns off? If so . . . following is the information I found in the Lifesmart heater manuals (several different models:
(Quote)
Overheat Safety Feature This heater is equipped with an overheat safety feature. When the internal components of the heater reach
a certain temperature that could cause overheating or possible ?re, the heater will automatically shut of
(End quote)
If that is the case with your heater, you will need to let it cool down before restarting it. You will need to make sure the Power button is turned to Off and then unplug the heater to allow it to cool down.
If you indicate the model of your heater, I will try to find the right user manual for you to download.
Target Corporationheaters buying guide > ... (125) reviews for Lasko Tower Heater with Electric Control ..... (23) reviews for Lasko Digital Ceramic Tower Heater with Remote.
Amazon.com, Inc.Amazon.com - Lifesmart Meduim Room Infrared Heater w/Remote - Space Heaters. ... This compact heater also includes a new larger remote control to operate the ... the best heater I have ever owned for my purposes and would definitely buy ...
Overstock.comBuying Electric Heaters: Tower heaters: Tower heaters are ideal for many homes .... Lifesmart Slimline Compact Infrared Heater with Remote Today: $102.99 4.4 (10 .... Dyson AM09 White Hot + Cool Fan (New) Today: $449.00 $499.99 Save: ...
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
