Question about Deadbolt Locks & Locksmithing
Wher can i get program manual for facto electroni deadbolt
I need to reprogram my password .. i lost my programming manual.
Posted by Roger Dario on
David L
    Scholar:
  • 135 Answers
Log onto the manufacturers website and you should be able to find the user manual for download or on screen viewing.
You will need to know your specific lock in order to find the correct manual.
Posted on Jan 08, 2015
3 Related Answers
Anonymous
SOURCE: changed battery and lost program cant find manual
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
Posted on Jun 02, 2010
Coaltowner
  • 963 Answers
SOURCE: My bioaxxis bd1 finger print
Here is the link to the website for the manufacturer, Axxis Biometrics:
http://www.axxisbiometrics.com/products/locks/deadbolt-fingerprint/bioaxxis-bd1/
I want you to have that because if all else fails, you'll have the contact information for further assistance.
Here is the direct link to the installation and programming instructions, which includes the beep codes. You likely lost the programming when you left the batteries out for such a long period:
http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Hope this helps. Good luck!
Posted on Aug 08, 2011
Coaltowner
  • 963 Answers
SOURCE: I have a touchpad Zurich
I have been searched unsuccessfully for "Zurich deadbolt keyless remote" in order to help you. However, if the picture shown in your request is accurate for your lock, I have found some information which may be useful to you!
The brand that I found is Lockstate, which looks like the lockset pictured. Go to this webpage (copy & paste into your browser search window):
http://www.lockstate.com/manuals-and-downloads.html?start=10
Go to the bottom of that page, to "LOCK LS-DBS" and click on Download. This will download a PDF file of the installation and programming instructions.
If you cannot open and view the download, you will need to download and install Adobe Reader. You can get it here:
If this is not the correct information for your lock, please re-submit the problem and I'll try again. Any further model info, etc., will be helpful.
Good luck--and please provide feedback if this helps!
Posted on Aug 26, 2011
I have a universal remote and lost my manual, put new batteries in my remote...and now have to reprogram for my tv can you tell me the code for a sharp tv/vcr combination?
Here is a link to download the manual with instructions for programming the codes:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4220-manual.zip&area=other
Aug 18, 2011 | One For All URC4220 Remote Control
The timer blinked low battery, we replaced the battery and now it needs to be reprogrammed but we have lost the manual. How do we reprogram it?
You posted under ST01C timer.
Open following page to read ez steps and download manual.
http://waterheatertimer.org/ST01C-program.html
Unless you reset the timer, then programming will still be saved forever.
Even if battery was dead, programming remains saved inside timer until timer is reset or stops functioning.
So all you need to do is set current time.
If the timer will not work, then reset timer.
Mar 27, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Need to reprogram the code but lost the manual
Hold down the 8 key until 2nd beep sounds. Enter the User Program Security Code. If this code has never been changed enter the default of 1+2+3+4+5+6. When the correct code has been entered the 1st 3 LED's will flash and the sounder will beep rapidly. Press the B/A key and then enter the User Code to be changed (1,2,3, etc.). Enter up to 4 numbers for the new code. Press the B/A key twice to exit the Program Mode. Hope this helps.
May 22, 2010 | Home Security
Changed battery and lost program cant find manual need reprogram 4 number code
Apr 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Lost owners manual need to reprogram the light
have you been to www.aerogarden.com. they have a troubleshooting area for the reprogramming of the lights.
Dec 30, 2009 | NRS AeroGarden 7-Pod Pro-100
Programing help
I have a oneforall remote for my 25" Emerson TV I lost the programing instructions. Can you help me program it?
Aug 25, 2008 | RCA DIRECTV Satellite Remote Control
Reprogramming keyless entry remote...
Believe it or not, the information and instructions for reprogramming your particular model of vehicle is provided in your owner's manual. The dealer does not need to be involved unless you have lost all your programmed and programmable keys.
Aug 19, 2008 | 1999 Ford Econoline
Locks & Locksmithing Logo
531 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Andrew Taylor
Andrew Taylor
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
