Question about Apple iPad 32 GB WiFi Tablet PC
How do i factory reset apple ipad i forgot my apple id and password
Posted by rosanna on
Rick kearney
    New Friend:
  • 13 Answers
Resetting the ipad will not help... The I'd and password are stored at the apple store.
Posted on Jan 08, 2015
I need to reset my apple password for my ipad
If you do not know the password, (not your machine) then a factory reset is the only option and all data will be lost.
If you cannot remember it;
If you forgot your Apple ID password
Apr 04, 2018 | Apple Tablets & eReaders
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Mar 19, 2017 | Apple iPad Tablets & eReaders
Remove iCloud lock from iPad
I am not aware of an ' iCloud Lock '. If you mean the user set passcode, the only way is to do a Factory Reset.
iCloud has a password, and that is the same one you use at the App Store. That has to remain in place to protect your credit card use. If you have forgotten that password, you can click Forgot Password link and a reset will be emailed to the email address associated with your iCloud/iStore account.
May 03, 2016 | Apple iPad 4th generation
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
Sep 14, 2015 | Apple iPad Air
Forgot iPad apple I'd and password
Go to https://appleid.apple.com/ and reset your id. You should have create security questions to answer. You had to use an email to create your id.
Sep 08, 2015 | Apple Ipad2 16gb White Wifi Face Time...
Reset apple id account
Unfortunately, you will need to get to a laptop or tower PC or Mac, in order to reset your password, migrate to apple.com try to login, there should be a forgot password link just below the login entry points. The Mobile version of Apples website malfunctions when attempting to reset a password, this is why you need to go through a laptop or tower to have a successful password reset.
Aug 16, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do i unlock forgot apple id password/icloud for a
The Apple ID is different from the iPad password, and is handled through iCloud. You may want to pursue this in Apple's help web site:
http://help.apple.com/icloud/#/mmfc0f1a3b
Aug 12, 2014 | Apple iPad 16 GB 3G Tablet PC
I cant unlock my ipad forgot my id can you help
You can connect your iPad to a computer and then do a factory restore to reset the device. After the restore you can set up a new password.
http://support.apple.com/kb/ht1414
Hope that helps!
Nov 29, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad 32 GB WiFi Tablet PC Logo
227 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
