Question about Homelite Garden
Lost manual does this weed eater take regular gas or is it a mix
Posted by Sam Herbert Swyers... on
Rick kearney
    New Friend:
  • 13 Answers
Want to give us a hint as to what kind of weed Eater this is? Most gas models use a mixture but the ratio can vary between manufacturers.
Posted on Jan 08, 2015
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Oct 05, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Do you add the oil first or the gas first?
If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I just bought a Weed Eater 22" gas push mower. Do I mix oil with the gas to run, as I do not see an oil input? p.s. I purchased this at a yard sale.
If it has a dipstick or plug to check the oil in the engine you do NOT mix gas and oil.
Use regular unleaded gas only and use 30 weight detergent oil in the engine crankcase if it is low.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
gasoline. Before operation, gasoline must be
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
159 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
