Televison & Video Logo
Set stations
Posted by gmb3917 on
David Payne
    Top Expert:
  • Televison & ... Master
  • 14,162 Answers
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Posted on Jan 08, 2015
    Top Expert:
  • 76,851 Answers
To set stations, you have to do an auto-tune to this set, after connecting it with either outdoor antenna or a cable connection. Gopakumar Gopalan Google
1helpful
How do i set the staions on my car radio
Look for a SEARCH BUTTON , Press button, when stations found , they will be on each station selector button, to keep station on any button , press button , then station is locked to that button
Lock ion a radio station
TO PROGRAM THE MEMORY BUTTONS
Ten FM and five AM radio stations may be independently set. After programming the buttons,
pressing 1, 2, 3, 4 or 5 will instantly change the frequency to the preset station.
1. Turn power on.
2. Set the radio to desired station (see Tune or Seek Function).
3. Press and hold one of the desired memory buttons (F). The station setting begins flashing in
the LCD display (G). Continue to hold the button down until the flashing stops. The memory
button is now set.
4. Repeat steps 2 and 3 to set the other memory buttons.
Please see the attached images for the figure options.
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
I want to know how to set radio stations on the 1-10 track set. Example: set station 96.5 to channel 5.
When tuned into a station, press and hold the number that you want to assign to that station.
7helpful
2answers
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Aug 26, 2011 • Garden
2helpful
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
How to program the presets for radio
hi, it sould be easy, i have never do this one before, but, normally. you need to find SEARCH UP or DOWN.
you may have 6 or 10 preset staions this due to 6 CD or 10 CD
PRESS SEARCH UP find the station you want KEEP PRESSING No 1 POSITION, you should hear a BEEP or the No. 1 station will FLASH, and let GO of the BUTTON, this STATION IS SET.
the next station PRESS SEARCH UP find station KEEP PRESSING No. 2 a beep should be heard or flash station No2 is set and let GO of the BUTTON. this STATION IS SET,
that is the basics and the same for all the stations
Radio goes into search mode when selecting pre-set stations
it is merely making the exact set connection
Setting up fav stations
seek to the station you want and hold down the preset button you want that specific station set to.
for ex: seek to 101.3fm and hold down the number 1 preset button for about 5 sec.
13helpful
2answers
Setting the stations on memory
OK HERE'S WHAT YOU DO
1. USING THE UP AND DOWN TUNING, TUNE IN THE STATION
2. PRESS THE MEM SWITCH (LEFT SIDE OF ROUND SWITCH)
3. PRESS STATION LOCATION
4. PRESS MEM AGAIN ---- THAT'S IT
SUMMARY: TUNE, MEM, SET STATION, MEM
Top Televison & Video Experts
Marvin
Marvin
