I have checked and cleaned coils. I emptied it of draws etc. unplugged it for a week repowered it. I worked for a short time. Then went back to blinking -2 and running hot. I pulled panel off freezer back wall, unplugged fan, plugged it back in and rotated it manually before plugging it back in.
Yes sounds like a bad fan or seal problem? if ur defrost timer or thermostat was bad u would eventually get severe icing?
Testimonial: "Vman was most helpful as he suggested defrost timer only problem is there isn't a defrost timer it has an inverter board that 'contains' an element that acts as a defrost timer. I took apart the whole refrigerator looking for the defrost timer. I temporarily replaced inverter board and the problem was resolved."
SOURCE: no cooling
I would first check the defrost timer...It may be stuck in defrost position and not advancing to the cooling mode, a common problem...There is a slot, clutched cut, to keep it from being turned in the wrong direction and if you can get to it, place a screw drive in the slot and turn it slowly until you hear a click and/or the compressor start...Some timers are located in back, some in front( bottom), and others inside the refrigerator close to the thermostat...If this does the trick a new timer may be in order, but often it may not happen again...I would replace it anyway to keep from losing food...If the compressor does not start, it may be a bigger problem and usally the overload, especially after a storm with a power off on situation..Overloads burn up from to much amp draw, starting, or trying to start the compressor to soon after it stopping...The compressor pumps up on one side and pulls in on the other creating a pressue difference that must equalize on the off cycle for the compressor to start again...If the off cycle is cut short, like a power off/on situation, the load is to much for it to start until the pressures equalize on the off cycle...Hope this helps.
SOURCE: SAMSUNG RS267LAPB
You have a defrost component failure. Either the defrost thermostat or defrost heater most likely. Bypass the defrost therm and place into defrost by turning defrost timer clockwise until you hear a loud click. if heater comes on then defrost therm is bad .If heater does not come on then it is a bad heater. you can check continuity with a ohm meter Hope this helps
SOURCE: i have a samsung RS2578BB
this is a common fault, you need to replace the defrost heater and thermal cut-out in the fridge section behind the salad buckets, a temporary fix for a few weeks is to switch the whole thing off at the wall and leave the fridge and freezer doors open for at least 24hrs to allow the frozen up evaporator to defrost.
regards
Ian.
SOURCE: For no reason, my freezer
You have either a sealed system problem or a control board problem. It's difficult to know which is which. You will need a qualified technician to determine what the problem is.
Good luck
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
