Question about PfaFF Sewing Machines
Replace snips knife in pfaff expression 4.2
Snips knife fell out when cleaning my pfaff. how do i put it back in
Posted by Carol Yelverton on
MissFixIt828
    New Friend:
  • 70 Answers
Take it to your pfaff dealer.
Posted on Jan 08, 2015
I am trying to get the left cover to stay on my Pfaff 2042 after changing the light bulb. What is the trick?
There are most likely some clips that hold it on and it's just a matter of holding your mouth in the right place... You can always try contacting a pfaff dealer. They may be able to show you how to put it back on.
Just wondering. The manual says to remove the accessory tray which is attached to the free arm. There doesn't appear to be a part of the case covering the bulb that should be removed. Did you remove a part of the case covering the needle mechanism and bulb? That could be the issue since the upper case should be removed only by a technician.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjQ762rvvbZAhXLhVQKHWFPCbIQFgg1MAE&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2Fexpression-2038_2048-manual-EN.pdf%3Fext%3D.pdf&usg=AOvVaw2bizLsuFjcpEwy7aHy6Pdx
Machine Support
Pfaff 2144 Instruction Manual Changing The Light Bulb
Mar 17, 2018 | Sewing Machines
Pfaff 1467 needle jammed in fabric and hand wheel stuck
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
May 01, 2017 | PfaFF Sewing Machines
Is it normal for the Pfaff snips cutter to be extremely noisy?
I bought a new Pfaff and was alarmed at how noisy it was, particularly the snips cutter. This was unacceptable and I sent the machine back, but I don't know if all machines with snips make this awful noise.
Apr 05, 2017 | PfaFF Sewing Machines
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
My overlocker does not cut the fabric the lower knife fell out and I put it back now It will not cut
the lower knife may need to be replaced, and the machine may need a adjustment
Dec 10, 2014 | Sewing Machines
Needle plate on Pfaff 1471 - removed to clean, when I try to put it back on it keeps popping back up. Is there supposed to be a
check to make sure the bobbin is seated correctly in the bobbin case & then try the bobbin cover, it's suppose to click or snap in
Mar 30, 2012 | PfaFF Sewing Machines
Pfaff 2020 Foot Pedal--taken apart; need help putting back tog.
Are you able to post a picture of what pieces you have? The contact board may not be pressed down all the way or the contact itself may be bent. You should be able to purchase both pieces if needed from a pfaff dealer.
Feb 24, 2010 | PfaFF Tiptronic 2040
Serger 794 from pfaff--calanda type 794
There are two holes running vertically inside the needle arm.........the needles are held firm by very small screws or hex allen keys.........they may have worked loose over time, if they have fallen out and been lost, it is a call to your  local Pfaff dealer for advice......be sure to quote model number.
Your User manual may have a diagram to assist.
Have you ever changed the needles since buying this machine ??
Needles ought to be changed every 6 - 8 hrs of sewing, and more often with heavy or abrasive fabric.
Nov 15, 2008 | PfaFF Sewing Machines
Sewing Machines Logo
167 people viewed this question
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Asmodius
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
