Epson LX-300 Matrix Printer Logo
r
rika mardiana Posted on Jan 07, 2015
My "tear off" of epson lx-310 was off, could you help me?
Take out the paper and then take in it again, then push button of font, but it is all zero
5 Related Answers
Anonymous
  • Posted on Dec 03, 2007
SOURCE: Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Anonymous
  • 159 Answers
  • Posted on Sep 06, 2008
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Anonymous
  • Posted on Oct 27, 2008
SOURCE: Auto Tear off for Epson LX300+
friends
you have to get the exact page size of your continuous paper. then you go to start -> printer and faxis -> then go to file -> and server properties.then create one paper which is exact sixe of your paper. Then go to printer preferances and select that paper.
to switch on tear off refer manual.
Hope this can solve the problem.
beerwin
  • 83 Answers
  • Posted on Apr 08, 2009
SOURCE: configuration of page length
Most of these older printers use a special key to enter setup...usually upon power-up. Have paper inserted, because that is where it prints it's configuration.
It will probably use some of the feature buttons to change the paper size and tear-off options. Sorry I can't help with a manual, but I hope this helps.
B)
Anonymous
  • Posted on Jul 29, 2009
SOURCE: setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
2answers
Epson LX-310
on epson LX-310 font draft condensed is not available, so if you want it, you must downgrade your printer. i don't know, why epson doesn't do this :(
if you want send raw data to printer, use escape command
2helpful
How to change epson lx 300 font size
Unfortunatelly you can not change the fontsize of the printer, but you can change the font.
To do this hold Pause button for 3 seconds, then push Font button. Two lights will light on and then off and will show you the current settings of the font. To change the font just click repeatedly the font button untill you reach the desired font following the combinations of light on the table below.
The fontsize is controled by the software you use.
17helpful
2answers
How to adjust font
Just switch off your power switch and twist it on once more and then press the paper out button for 3 seconds when you hear 1 beep that is the time you can alter font using the font button switch and desire the font that wants by pressing it. Pressing the Font button (tear off) for a small amount of seconds, the LEDs are lit and you can amend the font, the font depends on the light kit to make the LEDs, and each time summit strain changes in the last part of the manual.
1helpful
How to reduce size of font
Just switch off your power switch and turn it on again and then press the paper out button for 3 seconds when you hear 1 beep that is the time you can change font using the font button switch and choose the font that want by pressing it.
Good Luck!
2helpful
How can i change font in epsonlx-300-II printer
Here is how:
1. Printer should be turned on, but not printing
2. Hold down PAUSE button for 3 seconds. The pause light will flash and the 2 tear off (FONT) lights shows the current font selected
3. Press Tear off(FONT) button to cycle thru fonts till light indicate the font you want. When you select the font needed it stays in use as default till you change it.
Note: Some software can change the printer font selected.
If need more information about your printer check the manual
6helpful
2answers
Serial port settings Epson LX-300+
Make sure you have at least 10 sheets of paper loaded.
Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
2answers
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
63helpful
3answers
Changing font on Epson LX-300+
Paper is 8x7
The User guide is available on the Epson web site.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=6p8Gbf6kzcDjBDX5CN0IhYGAuQVqVCJs&tc=5
Essentially, this suggests (page 2-9) that you turn off, leave for 5 seconds min, and turn on holding the Tear off(Font) button. Press this button once and select the language, then press it again to print the settings and instructions for changing them. Set the printer to tractor-feed and your required length and you're away (turn off after).
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
