Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
How to reset the parential controle on a sony trinitron wega KV-27fs120
Lost malet
Posted by David Lacombe on
    Top Expert:
  • Sony Master
  • 76,416 Answers
Answered.
Posted on Jan 07, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
Jan 07, 2015 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony WEGA KV-27FS120 connected to LG BP200
What is the problem you faces when connecting this TV with LG Blu-Ray player?
Jan 19, 2013 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My sony trintron is stuck in stand by mode
If model number listed here (kv-27fs120) is correct the set if not coming on is in shutdown because either a problem in its power supply or something elsewhere pulling the supply voltages down and triggering shut down.
Someone would have to open and first check for voltages and or shorts--no real other easy way to troubleshoot this.
Mar 19, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No color on sony wega trinitron when hooked up to satellite, but plays movies in color
Try reprogaming your tv. And be sure you do not use a super video cord along side a yellow rca jack or components cords in the same aux. Check it out!
Nov 29, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony wega tv was on and it shut itself off and we tried to reset power and the standby light is now blinking red 6 times with no picture.
Why not try this.
If it is a tube type.
1. Turn off the TV.
2. Disconnect it from the outlet.
3. Connect the power cord after 1 minute
4. Power the TV.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Blinks
The blinking standby light should be in a repeating pattern of a fixed count of blinks. Please post that count here as that will indicate the circuit in which a problem was detected. Armed with that info, we can then tell you the problem and probable solution.
Thanks,
Dan
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-27FS120
This may be a power supply, and or a high voltage, or a scan ampplifier failure. The set would have to be properly trouble shooted by an experienced TV tech to determine the exact failure. This is not something you can fix yourself at home.
Jerry G.
Apr 15, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
as no sound on certain channels it means no problem in your tv though it is old. the problem is in transmission line from where you get prog. it can be adjudted manually by vol.control if low sound is there at certain channels. you can also reset once.
Sep 26, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
