My printer HP Deskjet 2515 does want to print from my computer it always did but not any more if I print test page the colours are ok but when I want to print a document the paper comes out blank
If the test page is working in colour then it's most likely your printer settings. Go into the settings when printing and ensure that greyscale or black/white printing is not turned on.
please printer driver setting .. give a print ...select your printer and go to printing preference then go to color tab check for any setting like print in color in gray and print in color ....... select print print in color ......and try ....
Try printing a test page. If it comes out missing colors, the you color cartridge is bad. HP test pages will print each of the 3 colors by them selves, so you can see if you are getting all colors. If this prints ok, the I would think it is not a printer problem.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I had the same problem and the solution I found was to uninstall and then reinstall the printer driver. For some reason this worked. I now get the correct colors.
