Question about Proscan Televison & Video
Need a code to have my cablevision remote control work on my proscan tv. none of the codes they provide work.
SOURCE: code for cablevision remote control
Hello Monica24g. I also have Cablevision and found the codes I was looking for. I assume you have an Audiovox (fpe1907) television. Here are some codes you can try: 076 103 043 035 224 228 078. Press the "TV" button and the "SELECT" simultaneously for 3 seconds. The IO button will light up. Enter one of the codes, then press the "TV" button again. I hope this helps!
Posted on Jan 05, 2009
SOURCE: Need DirecTV remote code for Proscan 26LB30QD
Direct TV Remote Codes for various devices.
Posted on Feb 15, 2009
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
Posted on May 30, 2009
SOURCE: need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Posted on May 13, 2010
Jul 31, 2014 | Televison & Video
Feb 11, 2013 | Curtis International New Original LED2440A...
Dec 06, 2012 | Proscan Televison & Video
Oct 18, 2010 | Proscan 32LA30Q Television
Jun 13, 2010 | Insignia NS-LCD19 19 in. LCD TV
Mar 19, 2009 | Proscan 32LA30Q Television
Feb 17, 2009 | Proscan 32LA30Q Television
Dec 27, 2008 | Proscan Televison & Video
Dec 05, 2008 | Vizio L32 32 in. LCD HDTV
373 people viewed this question
