Car Audio & Video Logo
E
Eric frost Posted on Jan 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pioneer htz 424dvd keeps shutting down every 30 minutes, even after following the operating manual instructions to turn off the auto power
Followed the instruction manual
Silas Lawrence
Level 3:
  • Master 906 Answers
  • Posted on Jan 06, 2015
Silas Lawrence
Master
Level 3:
Answers
906
Questions
Helped
181920
Points
2158
Is there a save settings option on the unit
Testimonial: "Tks for reply, no save option. In option mode, I select the auto power off, select off toggle button (no save option) then you exit to main menu"
  • Saad Siddique
    Saad Siddique Dec 11, 2020
    What is the fix?? Having same issue
A question about Pioneer HTZ-170dvd Please Can I connect it to my laptop computer? If so can you explain how as I'm offered a new one to buy for a good price but I think its very old to run with a pc.
you want to play music or a film on the laptop and run it through the Pioneer HTZ-170DVD Region Free Home Theater System and through speakers?
I don't see why not. You would use the audio out on the laptop and connect to the audio input on the Pioneer. If the laptop has HDMI, it is even easier. Here is the manual.
Pioneer HTZ170DVD Manuals
ManualsLib https://www.manualslib.com > products > Pioneer-Htz...
We have 2 Pioneer HTZ170DVD manuals available for free PDF download: Operating Instructions Manual. Pioneer HTZ170DVD Operating Instructions Manual (102 pages).
PIONEER HTZ-55DV DVD SURROUND SYSTEM. POWER ... NOT ABOUT CAMERAS!!
Question edited for clarity and typo 'PioneeEr' (3 x Es).
Question moved from Cameras to the Pioneer Model category. Why SHOUT it is in the wrong category when you could have put it in the correct one yourself? You have 10,000 to choose from :>D
Please don't type in all CAPS, it is considered SHOUTING, is RUDE and also harder to read.
The internal cooling fan has failed and needs replacing. Take it to your nearest Pioneer Service Centre. It is a cheap repair, or open it up and replace it or even vacuum up all the fluff and lubricate the fan.
https://www.google.com/search?q=PIONEER+DVD+SURROUND+SYSTEM+HTZ-55DV....POWER+COMES+ON%2C+DISPLAY+SAYS+CT+FAN+ERR
How do I set my sc pioneer receiver switch to auto standby mode
Using All Zone Standby; Setting The Switching Time For The ...
https://www.manualslib.com > Pioneer-Elite-Sc-91
Pioneer Elite SC-91 Manual Online: using all zone standby, Setting The Switching Time For The Receiver Operation Mode, Resetting The Remote Control ...
Operating Instructions - Pioneer Electronics
https://www.pioneerelectronics.com > PUSA > Manuals
PDF Increase the separation between the equipment and receiver. - Connect the ... Using the SR+ mode with a Pioneer flat panel TV . ... Plug the power cable into the AC outlet and switch on the receiver.1 Make ... See Automatically setting up for surround sound (MCACC ... 4 Optical and coaxial digital audio inputs (x7 (SC-07),.
AV Receiver - Pioneer Electronics
PDF The STANDBY/ON switch on this unit will not completely shut off all ... Plugging in the receiver . ... Automatically conducting optimum sound tuning (Full Auto MCACC) . ... Setting the switching time of AV amplifier operation mode. ... On a Mac, launch Safari and click <SC-85> displayed in 'Bonjour' on the Bookmarks bar.
https://www.pioneerelectronics.ca > Manuals > Home
PDF Before plugging in for the first time, read the following ... The STANDBY/ON switch on this unit will not ... Connecting a satellite/cable receiver or other set-top box . ... Switching on/off the Acoustic Calibration EQ, Auto Sound Retriever or Dialog ... For the SC-65, the optional AS-BT200 Bluetooth adapter works together with ...
Toshiba Regza 52rv535u will not turn on
Try different power cord. Try a different outlet.
Take it to a repair shop.
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
1helpful
Oven wont turn on due to auto mode.Cannot cancel auto mode.
If you have followed instructions properly, and cannot get it off auto. then you will need a new timer, alternatively, the timer can be bypassed
Dec 07, 2008 • Ovens
2answers
INFOCUS Lamp replacement
you tried holding down both of the volume keys for 10 seconds while powering up?
8helpful
2answers
Pioneer htz-77dv Tray Lock
We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
TV won't turn on.
Thats the code for convergence. This is something you can repair yourself for under 30 dollars. You will need the service manual to adjust your set after repair. Go to the following link and they have your service manual for 10.99 and that includes unlimited support to help you repair your set. They will even provide the link to order your part. After you order, if you will click on the contact us link and provide your email address they will instantly email your manual and instructions on how to enter into the chat sessions. I am one of their techs.
http://servicemanuals.vstore.ca/
Auto Power Off function?
To conserve battery power, the camera will shut down if an operation is not made within 3 minutes (default setting). The auto-power-off period can be changed in the setup mode to 1 min., 10 min. or 30 min. at user's option. When using the AC adapter, the auto-power-off period is set at 30 minutes.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
