Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
Following instructions which is, Press and hold the WPS button untill the wIfi led lights and wait 2 mins for the 2.4G or 5G leds to light and in the mean time press the WPS button on the router (doesn't have WPS button) and the band lights should light to show connection. No leds light up.
Posted by Tony Doyle on
stephen Adams
  • 2,219 Answers
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
Posted on Jan 23, 2015
5 Related Answers
Anonymous
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
Posted on Apr 20, 2008
marked
Mark Gil
  • 6487 Answers
SOURCE: No WIFI on D-link Router
If the wifi light is off its a sign that there's something wrong with it, so the first thing you can do here is to reset the router, To reset it press and hold the reset button of the router for 30 seconds and then power off the router for 10 seconds....
Posted on Aug 09, 2009
TechyDrood
Justin
  • 2072 Answers
SOURCE: I have a 2-wire 2701HG-B
Doesn't look like your router/modem supports WPS, here is the manual. http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf
I would check your Range extender model because some allow for a wired configuration
Here is a How To, to configure the extender via cable and utility http://support.netgear.com/app/answers/detail/a_id/41
Here is a list of Range extender models http://support.netgear.com/app/answers/detail/a_id/34
Posted on Jul 09, 2011
SOURCE: not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Posted on Nov 20, 2011
Dennis Engelking
  • 643 Answers
SOURCE: where is the wps button to connect a 327w westell
The 327w does not have a WPS button you need to configure the printer manualy
Posted on Dec 28, 2011
What does WPS button stands for.
WPS=WiFi Protected Setup. This is typically used to connect a Wireless Router to a Wireless Repeater. Both must be WPS capable and using WPS is similar to pairing two Bluetooth devices. One device transmits WPS and another listens (after you initiate a WPS sync). You have to enter a WPS PIN and the devices should connect.
Jul 03, 2017 | The Computers & Internet
I need how to set a password on the wifi AC1200
login to the router main interfacew normally by 192.168.0.1 the user and password are on a sticker on router somewhere and then there will be a tab in interface that will say Wireless the pass word can be changed via there. another alternative is if the router has WPS just press button on rpouter and on device find WPS connect in wifi settings and it will auto connect.
Sep 17, 2016 | NetGear Universal WiFi Range Extender...
Why did the router ID change when I linked it via the Wps button to the DSTV wifi gadget ?
Here's and excerpt from the Netgear WNR2000 user manual explaining that this is normal behavior for Netgear routers that support WPS..:
  • Keep Existing Wireless Settings. This check box is automatically selected after WPS is enabled to prevent unwanted settings changes, and is also selected if you have already specified wireless security settings or your SSID without using WPS. When this check box is not selected, adding a new wireless client using the push button or the Add WPS Client screen (see "Push Button Configuration" on page 2-14) changes the router's SSID and security passphrase. You might need to clear it if you are using certain registrars, such as for a Windows Vista PC, to configure the router through WPS.
Even if your router is not a WNR2000, it is likely that the configuration interface pretty much the same so you might be helped by looking at Chapter 2 page 17 in the WNR2000 manual here..:
Or else, go to Netgear support (NETGEAR Support Welcome), select Wi-Fi routers and download/display the user manual pdf and search it for "disable router's pin" or "keep existing wireless settings" and verify/change the setting so the router doesn't make changes when you use the WPS button.
May 20, 2016 | NetGear Computers & Internet
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
where is the WPS button? - Canon Community
community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Nov 19, 2015 | Computers & Internet
I am connecting my new canon wireless printer and it says to push the wps button for 5 seconds where is that button
Press the WPS button on your WiFi Router (if equipped) to automatically negotiate and store a secure password for the printer when opting to connect via WPS.
Oct 29, 2015 | Canon Office Equipment & Supplies
What does "wps" mean?
WPS is wifi protected set up.
It is advanced feature available on wireless routers and wireless devices
it is available as button
when a user wants to establish connection , he needs to press the WPS Button on the router and then on the wireless device he wishes to connect to establish connection
this feature is for wireless security purposes
Aug 06, 2013 | Computers & Internet
Stop wps
? WPS is just a wireless security setup protocol ? It is only active for a few seconds during node connections.
Nov 26, 2012 | NetGear WGR614 Wireless Router
Wifi wont connect
The wps number on the bottom of your wireless router many times is the password to get on to your wireless router. Try using that as a password.
You can look at the diagrams on the following link. It should help you a lot:
http://www.wikihow.com/Find-Your-WEP-Code
Aug 18, 2012 | Tablets & eReaders
I am trying to hook up a netgear universaL WIFI INTERNET ADAPTER to my tv and it says to push the WPS button on my router and i dont know what to push
The dlink dir 615 wireless router hasnt got wps. So its no good trying to connect it via that way you can only do it via wep or wapor wap2 here is a link to the manual for your router http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Mar 11, 2011 | D-Link DIR-615 Wireless Router
I have two laptops and want to set up a wireless network. I have the wireless set up but it isn't secure. When I go in to the Homegroups page it asks me for a 4 or 8 digit PIN number found on the router....
If you don't know it, you won't be able to automate your Wifi Protected Setup (WPS). The pin is a very specific way to prevent yourself from always having to remember codes, keys, passphrases, etc. Without it, its like saying that you want to to connect to Bank of America, and that it's just okay because you want it to happen.
The following is taken from the ESR-9753 manual:
- Wi-Fi Protected Setup (WPS)
WPS is the simplest way to establish a connection between the wireless clients
and the wireless router. You don’t have to select the encryption mode and fill in a
long encryption passphrase every time when you try to setup a wireless
connection. You only need to press a button on both wireless client and wireless
router, and the WPS will do the rest for you.
The wireless router supports two types of WPS: WPS via Push Button and
WPS via PIN code. If you want to use the Push Button, you have to push a
specific button on the wireless client or in the utility of the wireless client to start
the WPS mode, and switch the wireless router to WPS mode. You can simply
push the WPS button of the wireless router, or click the ‘Start to Process’ button
in the web configuration interface. If you want to use the PIN code, you have to
know the PIN code of the wireless client and switch it to WPS mode, then fill-in
the PIN code of the wireless client through the web configuration interface of the
wireless router.
Jun 28, 2010 | EnGenius ESR-9753 SOHO Wireless Broadband...
Computers & Internet Logo
526 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
