Question about KLH Audio Players & Recorders
When hooked up from the recoever to the input connection did turned the light in the back of the KLH sub woofer red and no reactions at all.
An often overlooked issue with quiet or no sub woofer output is that if the front and/or mid are set as Lrg or Med there is no SubWoofer or it is drastically decreased. So check your speaker size and you be pleasantly surprised by the ,return of the missing thump. Your neighbors? Not so much ;)
Posted on Feb 01, 2016
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Posted on Jan 16, 2015
