Televison & Video Logo
Question about Alba Televison & Video
Hi, bought a replacement remote for Alba DVD player 65/B, but can' Cannot get replacement remote for Alba DVD 65/B to work. identical to the old one, do I need to set it up in some way?
All buttons, new batteries. Searched for setup instructions on internet, to no avail.
Posted by Simon Coram on
5 Related Answers
Anonymous
  • 42 Answers
SOURCE: Have a Toshiba HD-A3KU HD
This does not sound at all like user error. That is covered under the manufacturer's warranty. Take it to Geek Squad at any Best Buy to have it sent in for service under the warranty.
Posted on Apr 12, 2008
Anonymous
  • 5 Answers
SOURCE: AudioLogic DVD-108 - help setting up component cables (no picture)
This may not be a solution, but is a good start. I recently bought a house with the theater system installed, but no remote. Had similiar problems with some functions on Universal remote. Did a google search and got the remote for my system and presto! I did a google on the DVD-108 and saw a AudioLogic remote(similiar, Originals are no longer available), and saw that there is a "setup" button as well as others that may select inputs. This may not be a solution, but would be a good start. Worked for me!
Posted on Jun 26, 2008
Anonymous
  • 22 Answers
SOURCE: Need replacement battery for Durabrand Portable DVD Player
Have you tried Ebay? If you used to proper charger, you shouldn't be able to "overcharge" the battery unles the charging circuit is bad. When battery is attached, will the player "ON" lite come on? Will it try to play a DVD/CD ?
Posted on Dec 29, 2008
RixsFixes
Radio Code Pro
  • 2200 Answers
SOURCE: I need the 3 digit setup code for a DWM-380 Sanyo
Try 147 - that is one for Sanyo DVD players.
Also try 003, 007, 010, 020, 053, 057, 082, 102, 187, 166, 187, 214, 266, 511.
Hope one of those works for you. Be aware though that depending on the remote you are using, it may or may not be programmed with the right code for this Sanyo DVD player.
Anyway I hope this helps. Thanks for using FixYa.
Posted on Jan 06, 2010
Anonymous
  • 6771 Answers
SOURCE: Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Posted on Jul 19, 2012
Hi can anyone tell me the region free code for a alba CDVD2251N dvd player
Switch on the DVD Player and go to next step
Press Setup button on remote to show the Setup menu
Next key in code 1389, a different menu should show
Scroll down to where it says Region 2 and change this by keying in 0
Press Setup button again on the remote to exit Setup menu
That's it, you should now be able to watch any DVD
Alba dvd manual
Manufacturers often stick to the same remote frequencies, so give it a try. The old remote may work again, if you carefully clean the battery contacts. The reason it's not working now is probably because the batteries are not making food electrical contact.
65" vizio new and my remote won't work
i think that you have to program the remote
Alba dvd universal remote code
help me guys with alba dvd59 remote codes
2helpful
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
Universal remote code for alba lcd22880hdf tv?
Hello
Universal remote codes for Alba TV with Chunghop RM-962 remote control are:
0705 / 0711 / 0730 / 0731 / 0738 & 0744.
OK.
3answers
I have been bought a Alba 1.8lcd MP3 palyer and have installed the cd it came with and it comes up in my computer but after ive put music on it and then go to play it it just says empty file ???
1. May be there is a particular music folder in which you have to copy the songs.
2. otherwise there is something wrong with the device and get it replaced.
3answers
Code for bubble console
the codes in the book are
0768 0770 0831 0881 1097 1115 1165
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
