Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Where could I buy a new gas tank for my Murray 12.5 riding mower? Has a Briggs & Stratton Engine?
Install shutoff valve between tank and carburetor, and change the oil
howdie sunds like your air line gin to carb is pluged and depends on how old it is the oil rings could be goin the air ine is on the side of carb,should be two screws holding it n so check that you might be doin ring job if you only got time on your hands otherwise look for another one soon
I have Murray 42" Rideon mower model 42591X8B with a new Briggs and Stratton 17.5hp single cylinder motor. I need the wiring diagraham for this model. Cheers
