When calibrating the display, the last target is in the correct place, however, the calibration will not complete unless I touch several inches towards the center of the screen. The first three targets select correctly. Had this problem before with Mavericks and it took uninstalling the tablet, deleting the library files and reinstalling. Worked correctly after installing Yosemite until today. What I want is this to work correctly without doing the uninstall delete reinstall procedure. I don't have that kind of time to mess with this every time I need to recalibrate.
SOURCE: wacom 12 wx cintiq
I had the same problem at first but managed to solve it. In my case I was setting up in tandem with another monitor and once I had correctly set the pixel dimensions of both monitors and set them to to 'mirror' mode it works pretty well. The only issue now seems to be a slowing of stroke speed ie the cursor lags behind my strokes. I have downloaded a new driver but not installed yet. Does anyone else have this problem?
SOURCE: installation problem
After much reading and searching and not finding anything I decided just to download a newer driver from their site wacom.com. It worked perfect! So the CD that came with the tablet is probably out dated!
SOURCE: I plugged my tablet in today and it, for some
try recalibrating it. otherwise, you'll have to send it in for repair or replace it.
SOURCE: I just got a cintiq
I had this same problem and just had to go into my system preferences on the imac and select display and then select/check the mirror monitors and now it is on sync-hope that helps! After I did that though my color is off on the cintiq so I am looking for suggestions on how to fix it as the calibration did not fix the problem.
