Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
C
Chuck Farneth Posted on Jan 06, 2015
It appears that F1-1 is the touch pad for the Maytag Gemini. Is it the same for all models?
I have unplugged the unit and tried to reset, but no changes. This is my first attempt to repair the problem. Beeping is driving me nuts.
5 Related Answers
Anonymous
  • Posted on Jan 18, 2008
SOURCE: Maytag Gemini Gas Double Oven
turn off the circuit breaker for a minute or two -- or unplug the range.
Anonymous
  • 43501 Answers
  • Posted on Oct 02, 2010
SOURCE: Maytag gemini oven - all
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Anonymous
  • Posted on Nov 21, 2010
SOURCE: Maytag Gemini electric double oven: Oven Control
I have the same problem with my stove but I do have auto select for the lower stove as well as keep warm for the upper,is there a reset button?
Anonymous
  • 643 Answers
  • Posted on Feb 25, 2013
SOURCE: code f9-5 on maytag gemini oven mer67752bab
Depends which model go to the following page it list the errors and the problem
http://www.appliancepartsquick.com/MaytagRangeFaultCodes.html
bmyers_1963
Bill Myers
  • 251 Answers
  • Posted on Jan 01, 2015
SOURCE: maytag mgr5750adw stove beeping .. No code display .. Pre heats to temp. then then turns off
Change the electronic control/clock board and the oven sensor.
2helpful
Have a F1-2 error for my maytag range.. the stovetop works fine but the ovens don't
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness.
1helpful
2answers
1helpful
F1-A IS FLASHING What does that mean?
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
I have a Maytag Gemini, it has the following codes F1-1 and F3-1
This is a bad touch pad on this unit. You normally have to replace the touch pads when you replace the sensors.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance questions and parts for all your appliances.
Happy New Year to you! Ella
Electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
2answers
Gemini electric range from maytag
Just unplug it and plug it back in. It will reset it.
Refrigerator Controls
try un plugging the unit for a day, see if the unit would reset by itself. look in the owners manual for a reset procedure if it has. otherwise replace the electronic module. or it could be a touch pad problem. the touch pad is like a switch for the module to understand the command.
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
