Well neither code has anything to do with it not starting.
Code 411 is a problem with the air injection pump, and 1000 usually means the car has not been driven far enough yet for the computer to check all sensors.
Are you saying it won't crank, or won't start ?
Trevor: Alittle known fact is that most Chrysler cars do not need a full OBD code reader! By performing the "Key-Dance" you can show the codes on the odometer without any reader! Look for info on how to read the codes with the ignition key.
On your problem, you need to check the wiring and connectors, and also check the proper cams and belt timing, as it is difficult but sometimes an out of timing (one tooth only) misalignment can make the car not to start.
Amclaussen.
If you can get a list of the codes It may help the experts to see a common item that affects all the codes. We need to know in what areas the codes were apperaing
The codes have nothing to do with starting or not starting the car. No start means it is either getting no fuel or no spark. The codes are to diagnose a driveability or emission problem.
reading codes is must to a engine with computers..if your light would flash 1 time then 3 this called code 13.. your only flashed 2 time could be code 11 or code 12 get on internet and look up the code... you can all so try to disconnect the postive side of the battery for 5mints.. this should clear any codes..hook battery back up..start engine if engine runs first time..you got a something in your ingction system that not working write..
