Question about Sony XM-2150GSX Car Audio Amplifier
I have a sony xplod 800w xm-475gsx
The amp was working fine, then it just stopped-no sound. checked Power to the unit and it was OK but on the top, the green power light doesn’t light, thus nothing??? Any suggestions?
Posted by s_desiderato on
4 Related Answers
Anonymous
  • 48 Answers
SOURCE: No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Posted on Jul 14, 2007
Anonymous
SOURCE: sony xm
internal heat capacitor or even a bad connection indside amp is bad giving you a hi output load wich the amp has an auto matic sensor to send it into this offset you speak of so it does not burn up
Posted on Sep 22, 2008
Anonymous
  • 18 Answers
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Posted on May 27, 2009
Anonymous
  • 5 Answers
SOURCE: my 600w power amp XM-554ZR wont turn on
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Posted on Jul 14, 2009
Not enough bass. should i run a capacitor.adjust my amp and what to set it at for max performance
Turn up the gain on your amp until you get the amount of bass you want or until the sub starts to distort. If you do this and you are still unhappy with the bass, you will need a bigger amp or better subs.
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
1helpful
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Sony explod 800W amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Sony XM-475GSX
try to change your ground location and or try a ground isolater loop
2answers
Amp problems
disconnect all power to reset try after 20min
Sony XM-2150GSX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
