Polaroid PTAB1050 4 GB Tablet - 10.1 - ARM Cortex A9 1.60 GHz - 1 GB RAM - Android 4.1 Jelly Bean - Slate - 1024 x 600 Multi-touch Screen Display - Bluetooth Logo
J
Jacob Matthew Pyrtle Posted on Jan 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset my tablet to factory settings
Pushing the reset button
micky dee
Level 3:
  • Polaroid Master 3,015 Answers
  • Posted on Jan 05, 2015
micky dee
Polaroid Master
Level 3:
Answers
3015
Questions
0
Helped
1061141
Points
8762
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
2answers
Can my son's forgotten password on his Zeiki tablet be manually overriden?
You have to reset your tab its at the back of your tablet .or you may go nearest service provider to unlock it.if is not working go to unlock account enter your user name then choose pattern enter your new pattern and then enter it again for confirmation..or u shut down the device then hold the power button hold again the volume up and the power button together.you see the recovery mode scroll down the with volume down button press the factory settings using the power button..then press the power button again to reboot make sure your battery is fully charge.
How to reset to factory settings on Tesco connect tablet
Your tablet runs Window 8.1, I believe. Provided it boots up, it's pretty easy to reset it to factory specs.
1) Slide out the Charms
2) Click on the Settings Charms icon
3) Click on PC Settings
4) Click on Update and Recovery
5) Click on Recovery.
6) Choose one of the three options.
If it's not booting up, I don't know what to do other than try how Androids do it by. Pushing and holding the power button and the volume(-) buttons at the same time until a reset screen comes up.
2answers
How to opn a matricom tab nerox2 with pattern lock
more than likely all you have to do is just do a factory reset you do this by pushing the power button and the down volume at the same time and then when you see the Android Logo , let the power button go. It will then go into the reset mode. look for factory data reset use the arrow keys on the volume button to maneuver, the power key to choose option. reset to factory settings. you lose all your data but the lock will be gone.:-D
1helpful
How to reset Prontotec 7 Inch HD?
Hi
Do you mean reset the Tablet? These Tablets don't have mechanical HHD they are IC's.
If you want to reset the Tablet to factory settings use a small stiff wire such as a paper clip, eye end of a sewing needle. Push it into the small hole between the earphone & HDMI sockets on the side of the Tablet. Push the reset button to reset Tablet
I have locked myself out of my tablet
You will need to do a factory reset:
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Forgot my passcode symbol on my tablet an need to reset it please
This works with devices having physical home button
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Can i restore my Polaroid tablet to the factory setting without messing up my iphone and laptop files?
Yes. Some of the older models have a reset button, you have to push with a safety pin. The others have the reset feature in the settings. You can choose to leave the mini memory card in the tablet to clear it or remove it before reset to save the non factory stored apps on it.
Top Polaroid Tablets & eReaders Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
nexrad_chris
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
