Question about Car Audio & Video
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and says no video. There is only 1 output coming from the DVD headrest and only 1 input into the monitor.
    New Friend:
  • 6 Answers
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Posted on Jan 05, 2015
Testimonial: "The screen that turns blue only turns blue when a video cable is plugged in"
  • Vanny D Meas Jan 05, 2015
    the screen that turns blue only turns blue when the video cable is plugged in
4 Suggested Answers
Anonymous
  • 14 Answers
SOURCE: Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Posted on Mar 08, 2007
Anonymous
SOURCE: TView headrest dvd player
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Posted on Feb 25, 2008
Anonymous
SOURCE: vIZUALOGIC Headrest monitor
press menu, under the sub menu turn the parking off
Posted on Jan 15, 2009
Justin Peters
  • 225 Answers
SOURCE: Is there a customer service
Here's the link for the return authorization form they have you fill out online:
http://www.poweracoustik.com/pa2006/form1.htm
Here's their contact information:
Power Acoustik Electronics
1550 S. Maple Ave. Montebello, CA 90640 USA
Phone: 323-722-3333
Fax: 323-722-1122
http://www.poweracoustik.com/pa2006/CONTACT.htm
Posted on Nov 08, 2010
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
Directed 10.2
remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
Oct 25, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
Power Acoustik DVD headrest shows blue screen/red welcome on start, won't play
sd sa dsa das dasd as fasf as
[url=http://www.rezibis.com/]headrest monitor[/url]
[url=http://www.rezibis.com/]headrest dvd player[/url]
Jan 02, 2013 | Car Audio & Video
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Walmart dual headrest dvd player has no sound on passenger side
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
HEADREST dvd player honda odyssey 04 exl
Do the headrests detach?? If they do, you can buy the pair of 7" headrest DVD/Monitors all-in-one from Farenheight (made by Jensen). I have used these several times. Not only do the headrests match,but the product lasts too! The best part is that they are about 1/2 the price of many others.
Larry T
Winona Lake, IN
Jan 28, 2009 | TMI Products Vizualogic Headrest Pair...
10.4 inch headrest lcd monitors
MOST OF ALL VIDEO OUTPUTS AR NOT STRONG I SUGGEST
ADD A VIDEO AMPLIFIER
Mar 18, 2008 | Car Audio & Video
VIZUALOGIC Headrest monitor
Jan 07, 2008 | TMI Products Vizualogic Headrest Pair...
Car Audio & Video Logo
242 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
