Question about Toys
Anyone have the manual for a radioshack RC surveyor drone (red) one of the props seems to have reversed and its not flying. I KNOW the props are on right and everything is checked. It seems to be like stuck inna flip. Pls help :(
Posted by spencer runnfolls on
Xena Garcia
My Drom only the white light are on but very light and the other lights don't turn on
Posted on Oct 04, 2019
Jack Meehoff
    New Friend:
Took me a while to figute it out but it goes like this...looking at the top of your drone, align your proppellars horizontally. The inside propeller in the front should slope down toward the front of the drone and the back propellers should slope up towards the nose.
Posted on Sep 13, 2015
1 Related Answer
Anonymous
SOURCE: my double horse 9053 volitation hellicopter rc
I have the same problem, did you find out the answer?
Posted on Dec 20, 2010
I'm trying to find the instruction and operational manual for a radio shack surveyor camera drone
Model Number and manufacturer helps find manuals on the internet.
Is it this one?
https://www.manualslib.com/manual/1221176/Radio-Shack-Zeraxa-6001352.html
Mar 05, 2018 | Radio Shack Radio Communications
My controler will not fly the drone. The drone is in ready to fly mode(lights slowing flashing) but thats all.The motors will not turn on.
Check if drone is fully charge. LED lights needs less power than motors. Maybe that is why LED is glowing. If drone is fully charge, check if there is any unwanted material stuck near the blades which are creating extra fiction on the motors. If you are looking to buy another drone, here are some of the mini drone with camera that you can buy in less possible price. 11 Best Nano Mini Drones With Camera You Can Buy The Tech Toys
Feb 04, 2018 | Cameras
My fuse x22 drone blades will spin and it will sync but it will not fly. Any ideas?
Drones are available for kids and for adults so everyone can fly a drone so, I can suggest you take a look at and find some good drones.
Here is my list.
1. DJI Phantom 3
2. Parrot Bebop 2
3. JJRC H37
4. Holy Stone Hs230
Dec 13, 2017 | Toys
Why was my drone flyiing perfectly fine and now it wont take off at all
I know this is new but it sounds like a battery pack issue. Replace the batteries and I bet you will be fine.
Feb 18, 2016 | Toys
Drone Tumbles?
could it be that the front propellers are reversed? I believe the top left propeller turns clockwise and the front right counterclockwise. If if that doesn't do it try placing the drone on a flat surface and holding the control with the joysticks at the bottom left and bottom right corners after pairing it with the quad. That's all I have. Good luck...
Dec 27, 2015 | Toys
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
Toys Logo
1,026 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
