Question about Kenmore Sewing Machines
My kenmore sewing machine is stuck in the reverse mode
It sews perfect but only goes reverse
Posted by Margaret Ann Fast on
  • Jimmie Sill Jan 06, 2015
    Hi Margaret Ann Fast, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? WHAT IS YOUR MACHINE TYPE?
MissFixIt828
    New Friend:
  • 70 Answers
The feed assembly is starting to seize. You will have to take it in to be serviced
Posted on Jan 08, 2015
Kenmore 385.1500 sews only in reverse. it is stuck in reverse sewing.
The reverse mechanism lube us going bad. It is accessed from under the machine under the free arm. Usually indicates that the machine is due for a service and oiling. It shouldn't be a problem to get it done at a good sewing machine dealer/store.
Nov 15, 2016 | Kenmore Sewing Machines
Viking only goes in reverse
Usually that is a sign that it has a stuck linkage that prevents the feed dogs from moving properly.
Apr 22, 2014 | Kenmore 16622 Mechanical Sewing Machine
Will not sew. When attempting to, it moves in reverse without setting it in reverse.
If you have had this machine for long time the problem is most likely the reverse mechanism is stuck. On a lot of kenmore machines the reverse is a spring loaded lob that slides side to side on the lower shaft. Over time the lube that was used dries out and turns pasty. The spring can no longer push the lob and the machine stops reversing properly. It needs to be cleaned and relubed. Best bet is a sewing machine shop with a good repair person. If it is a new machine it could be something else.
Sep 16, 2013 | Kenmore 16622 Mechanical Sewing Machine
My sewing machine sew backward
Many Kenmores get stuck in reverse because the lubricant used has hardened up on critical stitch length/reverse mechanisms. Take it to a good sewing machine repair shop.
Jul 21, 2009 | Kenmore Sewing Machines
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Kenmore 15516 It only goes reverse both ways.
Does it have an automatic buttonhole? If so, is the pattern selector set on part of the buttonhole? set it to straight stitch or Zig Zag
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Machine will only sew in reverse
Hi
Questions.
Does the machine only feed in reverse?
Will the machine feed as normal(forward).
If the machine will only work in reverse, then it is highly likely it is stuck in reverse and needs a good service to free it off.
It is very difficult trying to diagnose the problem without looking at the machine. A reasonable sewing machine tech should be able to sort the problem in no time at all.
Rob
Mar 27, 2008 | Kenmore 16622 Mechanical Sewing Machine
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
82 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
