Televison & Video Logo
Question about Alba Televison & Video
Reset code on alba tv so it will let me retune the channels
Posted by scott on
Dougie
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Menu, go down to features but not actually into features, then 4, 7, 2, 5, green.
Posted on Jan 05, 2015
How do i reset my pin code so i can retune my alba tv
menu, go down to features but not actually into features, then 4, 7, 2, 5, green. you have to do it quite quickly
or just menu 4725
MY ALBA TV SAYS NO SIGNAL EACH TIME i PLUG IT IN
Either the TV has lost its memory and just needs retuning; or your coax and/or aerial is stuffed.
6helpful
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
How to retune my alba lcd 22a dvd tv
I( cannot get any channels from bbc1 to channel 20 any ides please
Since retuning I have lost BBC 1,2,3,4 & Ceebeebees. I receive my transmission from Winter Hill, and have a Digifusion FRT 101 set top box connected to an Alba CTV3485SIL TV. I also use a Humax...
sounds like you need to rescan for channels, Should be in settings menu then maybe channels, Normally autoscan or channel update, Also make sure your airiel is good.
2helpful
After having to retune my Alba Freeview Digital Top Box - Model No. A002157058939 - on September 30th to allow for better digital reception of Channel 5, I am no longer able to receive ITV3. Have retuned...
You may need a better aerial. Digital TV signals need good signals or you can't pick up the full range of channels. Broadcasters and others are tending to keep their mouths shut about the expense of needing much better things on the roof than what many people use to get away with on analog signals. Even if you have a good aerial, If you have the 'brown' coax cable connected to it you could lose signal and stations. So it's best to replace it with Satellite coax cable FT100. That should stop a lot of blocking caused by interfearance by cars or those off road bikes youths ride around on.
7helpful
2answers
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
