Question about Dryers
Squeaky Kenmore Dryer
We have a Kenmore washer/dryer stackable unit that about 8 years old. The dryer has developed a high pitched squeak or squeal that is very irritating. I've taken the front panel off and sprayed the belt with silicone. It helped for about two loads and then it started again.
What do I need to do?
Posted by sandydelay on
Craig Butler
    President:
  • 1,730 Answers
The idler rollera and belt tensioner have got bearings. One of them is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 07, 2009
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
We have 98702. the dryer makes a loud rubbing, or knocking noise. at first listen, it sounds as if there were metal in the dryer rattling around. this is a steady noise. i am interested in fixing myself....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have a kenmore gas dryer model 70722990 when you turn it on it has a very high pitch squeal sound runs for 5 minutes then turns it's self off and won't turn back on. can you please tell me whats going...
heatman101
Asker
Dec 27, 2010 | Kenmore Dryers
I have a high pitch squeal coming from the back of the dryer
heatman101
Sep 17, 2010 | Fisher and Paykel IWL12 Top Load Washer
Model #970-c81032-20. Dryer makes high pitched squeal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 21, 2010 | Kenmore 83042 Electric Dryer
Squealing noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
289 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
