Use this tip to check your configuration.
If you cannot browse internet connecting with LAN cable to your router contact your ISP and check your router configuration.
If you set in your router a limited number of addresses for DHCP clients, be sure you can assign an IP address to every device.
also make sure DHCP is enabled on the router or you wont get any IP address or internet
Hello, There various causes for for the same symptom. So more information in needed. I need the model, and how you are trying to connect wired or wireless? If you connect to the modem directly, have internet? If yes, You can see the administrative page of the router (ex. if your gateway is 192.168.1.1, you enter this number on the browser to access the router). And how is connected the cables on the back of the router.
