SOURCE: Maytag Frig. Model MSD2651HEQ not working
Your start relay for the compressor is probably the problem. If ordered, you will most likely receive the relay and overload protector. Replace them both.
SOURCE: Sub-zero 550 series
I had this problem in the fridge portion last year and replaced the switch at the top of the door. Problem solved. There should be two switches: one for the lights and one to turn off the compressor when the door is open. I don't remember which one was which. Try the link below for the part, but double check to make sure it's the right one. They have an 800 number to call as well. Good luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=753971&PPStack=1
SOURCE: refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
If there is no refrigeration effect at all call for service, if there is partial refrigeration remove the grille in the front below the doors and make sure the condenser coil is not fouled with dust, with the refrigerator running the fan in the back should be running as well.
If the coil is full of dust use a vacuum to clean it best you can, if a clogged coil is the culprit cleaning is "some" will provide results.
If the fan in back is not running when the refrigerator is running call for service.
SOURCE: Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Testimonial: "Thank you! Got it fixed!"
