Question about Archos 605 WiFi Digital Media Player
I have an Archos 605 Wifi GPS and when I use it as a Sat Nav I get a 'check hardware settings' message. can you help?
Posted by Roger Healing on
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: Archos 605 WiFi "Cannot play video! Please Check"...
Happens to me at least once a week! Use the reset button - works every time.
Posted on Sep 09, 2008
Anonymous
SOURCE: Archos 605 WiFi stuck
mine did that the first time i opened it out the box and turnin i just pressed the reset buttion
Posted on Dec 28, 2008
Anonymous
  • 3 Answers
SOURCE: Web Browser Plug-in Archos 605
There is a seller on ebay (name is luhahaca) that says he is an Archos official Plug-ins reseller. Just search for 605 Plug-ins on ebay. He sells a four pack for only $38.00. I bought and installed them and they work great. Really makes the Archos functional - the way it should come out of the box. Actually, (sadly) the way it does seem to come out of the box - I was disappointed when I received my plug-ins download. All 4 plug-ins = 2kb. Web browser with widgets, extended movie and music capabilities and Real player mode. It seems to me that all of this is already in the Archos, they simply charge extra for a key to access it. It's a shame. Totally worth the price if you have an Archos, but really too bad they feel the need to force their hand into your pocket after you've just given them hundreds of dollars. I think the unit would be reviewed better, and Archos wouldn't look so petty, if these features were just enabled right out of the box. (my opinion anyways)
Anyhow, I hope that answered your question!
Posted on Jan 16, 2009
Anonymous
  • 5 Answers
SOURCE: Archos 605 running Vista Computer does not recognise the archose
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
Posted on Feb 22, 2009
Anonymous
SOURCE: map code
I had the same problem. "Invalid Map Code", etc. I went to archos.com/gps_install, and followed the directions. I had to update my 605 wifi firmware. Once I did that, I entered my map code and map version (found the version on a .txt file on the dvd, forget which one), and followed the directions from there. Seems to be working so far, although I haven't actually taken it on the road yet (can't seem to get a GPS signal in my garage).
I'll post a follow-up once I know it's working.
Posted on Apr 19, 2009
1helpful
I can't find the model number on my Archos 605 wifi 160gb - can anyone tell me where it is?
serial number or model number - isn't archos 605 is the model number? serial numbers are usually written inside battery compartment or battery cover and rarely displayed via settings/information menu
2answers
605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
4helpful
How to delete wallpapers .Archos 605 wifi.
Make sure the Archos is set tp 'PC Hard Drive' in the settings.
Plug the Archos into your pc, browse the drive and go into the System folder. All the wallpapers are in there - don't delete any essential files!
4helpful
2answers
I cant access my files when I plug my Archos 605 into a computer!
i had the same problem what i did was i downgraded my 605 to
Archos 605 Wifi (20GB-160GB) OS v 2.0.10
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04
heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos
and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
2helpful
3answers
Map code
2answers
Archos 605 WiFi in Windows Media Player 11
On your pc, go to Start\run, type diskmgmt.msc and click ok to take you into Disk Management.
In here, you can associate your drive with a drive letter.
Hope this helps......
Archos 605 wifi
I get it why people have to go around asking experts directly(your not the only one).
Can you tell me the connectors behind your television
Archos 605 copying films from DVD to the player
If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
Archos 605 WiFi Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Ngoro
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
