Question about WL Toys WLToys V913 Large 4 Channel 27" RC Helicopter 2.4GHz
My v913 helicopter took a little crash to the front and now my controller wont connect to my helly the red light on the helly used to blink to link up but now it just stays solid red
I have tried to link it up so many times
Posted by Kyle H on
Jose Severino
    New Friend:
  • 15 Answers
Sorry Kyle but you're going to need a new circuit board for that the 913 it crashed and must have cracked or something so you can have to change hair a circuit board
Posted on Jan 18, 2015
Controler wont control the copter the blue light is blinking on the helicopter and the red ligher on the controler is blinking aso. This happend after a crash
Make and model would help a lot here, but many of the controllers on the small remote control helicopters need to be reset after a crash disconnects the link. You do this by turning both the helicopter and the controller off, then turn the 'copter on first and the controller second. When the lights on the 'copter indicate a connection, take the power control lever on the controller and push it first all the way up, and then all the way down. This resets the controller and should enable the link again.
Mar 14, 2015 | Toys
My helicopter will not take a charge the remote lights blinks and the charge plugs will not turn off
If I understand well you are trying charge the helli with the power switch "on" . Turn of the switch on the helli and try charge again.
Jan 26, 2015 | World Trading 23 Hercules Unbreakable...
How do I charge a night hunter helicopter correctly
Charging time is about 25 minutes for the first chargings. Remember never charging the helli unattended!!!!!
Jan 18, 2015 | Generic Night Hunter Xtreme...
How do I attach mjxf45 tail motor to v913 circuit board (esc red wire black wire and white wire?thanks cessnaman
Both hellicopters have the same wiring for the tail motors (white blue) and I think the same motors. Anyway the wiring for any 3 cable esc with any 3 cable motor doesn't have a standard. If you place them "wrong" the motor will not spin to the side you want and you have to make another combination. Generally on rc planes, bellicopters, cars etc the three color cables have black color for ground red for voltage and white for singnal. You may also see black , red, wellow or brown , red, orange coloring with the same meaning. These cables are used most on receivers and peripherals connections.
Oct 01, 2014 | WL Toys WLToys V913 Large 4 Channel 27" RC...
My v913 does not respond to left turns. mode 2
i think it has something to do with the signal to heli from transmitter
Jan 15, 2014 | WL Toys WL V913 Sky Dancer 4CH FP...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Aug 06, 2009 | Shuttle 9094 Emax Remote Control...
WL Toys WLToys V913 Large 4 Channel 27" RC Helicopter 2.4GHz Logo
434 people viewed this question
Top WL Toys Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a WL Toys Toy Expert? Answer questions, earn points and help others
