Maytag EPIC MFW9700S Front Load Washer Logo
Question about Maytag EPIC MFW9700S Front Load Washer
Final spin /rinse cycle won"t stop
I have a Kenmore ECO Easy Care front load washer. When it goes into
the final rinse/spin cycle it won't stop. It also shakes violently. Can
you help me?
  • Anonymous Mar 22, 2014
    Won't spin through rinse or spin cycle
Ned Halaweh
  • 240 Answers
It's usually a control board problem. sorry for the bad news :(
Posted on Jul 07, 2009
  • Ned Halaweh
    Ned Halaweh Jul 07, 2009
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
2answers
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
2answers
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
1helpful
Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
1helpful
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
4helpful
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
