Koss KS4110 DVD Player Logo
Question about Koss KS4110 DVD Player
How do I connect my dvd to my tv and know the plugs are in the right spot?
There are two rows of red, yellow, white plug ins and not sure which one is correct
Posted by Michele Farhat on
2 Related Answers
kargol
  • 4 Answers
SOURCE: KS3102 Koss DVD player hookup to Toshiba how??
I have an owner's manual for that system and would be glad to copy the diagrams for you. Additionally, I think that you need red, blue and green wires from the back of the Koss to the inputs on the TV.
Posted on Dec 27, 2007
Anonymous
  • 3 Answers
SOURCE: PLAYING DVD
The unit is probably in pal mode. You need to set it to ntsc instead.
Posted on Mar 02, 2010
No sound while playing a dvd or cd in my valor dvd headunit radio has sound just not when i play a dvd or cd
Make sure your cables are in right spot on both..
DVD player (if using the composite cables yellow white red)
on DVD makes sure it says Video OUT and color match
TV look at the back and dont just plug in cuz you see colors. look at rear.
On Back where they are at should say Video 1 2 3 whichever one has the red yellow white cables and say Video IN. match colors then try. should work.
2answers
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
1helpful
I need detailed instructions on how to connect a wii console to an asus vw266h monitor
You need to get another cable for that WII that is for HD. It has 5 connnectors on it. The red and white are the sound, the other three are for the video.
http://www.amazon.com/s?ie=UTF8&keywords=wii%20hd%20cable&page=1&rh=i%3Aaps%2Ck%3Awii%20hd%20cable
I need to plug in a Xbox 360 into a samsung flat screen t.v using the : red yellow and white . And the green red and blue . . how should i go about this .... because im not sure wherre the cords go exactly...
You will use the red and white connections for your right and left audio, those go into an"INPUT" on the TV, then you will either use yellow, or red-blue-green for your video, not both, either yellow, or red-blue-green.
Make sure you connect all cords audio and video into the same row or group of jacks on the back or side of your TV.
Good Luck !
How do I connect the dvd to the TV?
You can try to use some rca's to plug into the dvd player and t.v. Rca's are Yellow (Video) White and Red (Left and Right Audio) and make sure your plugging them into the correct spot on the t.v and the dvd player.
I'm trying to connect my denon dvd player to tv
The yellow plug is composite video; the red and white are analog audio. Not knowing specifics about your TV or Denon model number, I would suggest:
-- the red and white connectors go to the audio in on the DVD, and to the audio out on the TV. There will be a left channel and a right channel. Make sure you connect the same color plug on the same channel. In other words, if you put the red plug in the right audio out on the TV, also put the red plug in the right audio in on the DVD, the white in the left audio out on the TV and in on the audio in on the DVD.
-- the yellow connector will go on the video out on the TV, video in on the DVD.
For better audio, consider using gold connectors, if you don't already have same.
Alternatively, you may wish to purchase and use an S-video connector if your equipment allows. This would replace the yellow composite video cable, and enhances your image.
Hope this helps!
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
1helpful
2answers
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
2answers
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Hooking up my dvd/vcr playing
The problem definitely lies in your connections. Make sure that the red is in red, white in white and yellow in yellow. If you have multiple sets of these to plug into on the back of your TV, then make sure that look at what that row is named (e.g. AV1, COMP 1, etc...).
Next, change the input on the TV (w/ the remote) to that name: AV1, COMP 1, etc...)
Top Koss Televison & Video Experts
Marvin
Marvin
Tom Chichester
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
