i-mate Jama 101 Smartphone Logo
g
gary murray Posted on Jan 03, 2015
Get instructions for the use of my new I phone
Turning it off and on making a call
Saurabh Middha
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jan 03, 2015
Saurabh Middha
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
652
Points
6
Its a new phone, must be under warranty. Take it to the service centre. They'll fix it !
Billy 0208
Level 1:
  • Contributor 32 Answers
Billy 0208
Contributor
Level 1:
Answers
32
Questions
0
Helped
5910
Points
51
Try support.apple.com for a manual. Hope this helps.
2answers
What to do when you turn on the phone but the screen stays dark? Just shows logo but shuts off again
I would do a factory hard reset (Google make and model number for instructions.), it is likely that will restore function, you will loose all stored data except what was loaded on the phone new.
Nov 01, 2018 • Cell Phones
LG flip phone will not turn on. LG logo lights up screen for approx 5 seconds, then goes dark again for approx same amt of time then repeats. Tried taking out battery and putting it back.
You should try a factory reset, just google the make and model for instructions to do the factory reset, if that doesn't clear the issue you need a new phone.
The red LED new call light doesn't turn off when there are no new calls. Any ideas?
What make and model phone? The new call light, or the new message light? If the latter then you have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
2answers
I can't get a dial tone. It says connecting and
It sounds like you have a defect in the main base, I suggest returning the item because you have gone as far you can go short of taking it apart.
1helpful
How to operate
"First, turn on Bluetooth and Bluetooth visibility in your phone. This makes your phone visible to other Bluetooth devices.
Headset instructions:
  1. Make sure that the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
  2. Press and hold the On/Off button for at least five seconds, until you hear along high frequent beep and the light flashes red and green.
  3. The headset is now in pairing mode.
  4. If your phone supports auto pairing, press Yes when the question "Add device?" appears in your phone. If not, continue with the next step.
  5. Prepare your phone according to the phone instructions on how to add a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
Phone instructions (NB: these may differ a little depending on phone model. For exact instructions, see Pairing instructions for the specific headset and phone model on www.sonyericsson.com/support.):
  1. Enter the main menu and go to Settings, then select the Connectivity tab.
  2. Select Bluetooth > My devices.
  3. When New device appears, press ""Add"".
  4. The phone starts searching for devices. Make sure that the headset is in pairing mode.
  5. When the headset becomes visible in the Devices found menu, highlight it and press ""Select"".
  6. Enter the Passkey (0000 by default) and press ""OK"".
The headset is now added to the list of paired devices and is ready to use."
3answers
What is the passcode for vh300 bluetooth sony ericsson?
Accessory instructions: VH300 Before you can use your Bluetooth
9helpful
Jabra BT2050 Bluetooth Headset not found on cell phone? I turned on the headset, and when i search for it, the headset doesn't show up. My phone just says "no new devices", and its not a known device
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
Sony Ericsson K660i
you need to go to the setting and make sure that the dim settings are high.
The phone will not turn back on
Okay, Does the Red light on the infa-red flash 5 or 6 times when you try and turn the phone on? If it does then you will need to flash your phone. Follow the instructions from the site you use (I use Wotanserver.com) When you plug your phone in, make sure that you hold and keep holding the 2 and 5 buttons untill the first two stages are complete. It will then tell you what to do.
Top i-mate Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
