Samsung HW-D450 Sound Bar Logo
j
joette bauer Posted on Jan 03, 2015
How do I connect Samsung soundbar 550 to sanyo dp55441?
Used hdmi cables but have no sound
Blaster Master
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jan 03, 2015
Blaster Master
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
4182
Points
19
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Connecting samsung sound bar to sanyo fvm3982 tv
Here are steps to connect a Samsung soundbar to a Sanyo FVM3982 TV using an optical cable:
  1. Locate the Optical Out port on the back of the Sanyo TV. This port will be labeled "Optical Out" and is usually covered by a small protective cap.
  2. Remove the protective cap from the Optical Out port and plug in one end of the optical cable.
  3. Connect the other end of the optical cable to the Optical In port on the Samsung soundbar. This port may be labeled "Optical In" or "Toslink".
  4. Turn on both the TV and the soundbar.
  5. On the Sanyo TV, use the remote to navigate to the audio settings. Look for an option to set the audio output to "External Speakers", "External Audio", or "Optical Out". Select this option.
  6. Adjust the volume on the Samsung soundbar using its remote control.
Once these steps are completed, the sound from the TV should be played through the Samsung soundbar. If you encounter any issues or don't hear any sound, check to make sure that the soundbar is set to the correct input and that the volume is turned up. Additionally, make sure that both the TV and soundbar are properly connected and powered on.
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
No to hook sound bar to element TV and my DVD player at the same time
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
How do I connect my ht ct260h step by step, with hdmi input do I use
HDMI can be a bit confusing when first connecting a system. Overall, the HDMI cable system allows for less clutter and digital audio and video, but you need some background to get it right.
The simple answer to your question is that the HDMI on your TV that is labeled HDMI out will go to your soundbar's HDMI input. Now, the reason you have a picture but no sound, will be one of 2 problems. If your TV is labeled with ARC, this means that it has an HDMI with Audio Return Channel and will be compatible with your CT260h soundbar. If you don't have sound, then you need to replace your HDMI cable with a ver1.4 HDMI cable so that ARC is supported in the cable design. If your TV does not provide ARC, then you will need to connect the audio using the digital optical connection which is a fiber optic cable of the TOSLINK variety. This cable should have been included with your soundbar packing.
Also be aware that if you buy a HDMI1.4 with Redmere technology to save on the size of the cable, it has a direction for the signal flow which must be adhered to, otherwise the cable will not pass either audio nor video.
I hope that answers your question.
1helpful
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
1helpful
How do I connect a Toshisba soundbar?
Your sound bar should have some sort of HDMI IN and HDMI OUT. This means that there are at least one place to plug a HDMI cable into the bar from either your dish or bluray player and then you take another HDMI cable and plug it into the port labeled HDMI OUT and this will plug into your TV either in HDMI1, HDMI2, or HDMI3 and then it will provide sound for the device. Unfortunately you didn't not list the item so I can not look it up to see if it can accept multiple devices so if it only has two HDMI ports then it can only support one device and you will have to manually change out devices through the HDMI IN port. Essentially the soundbar is just a pass though and takes the sound and sends the picture to the tv.
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
