Cars & Trucks Logo
Doug O'Brien Posted on Jan 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2012 Grand Cherokee V6. The audible chime & audible warning for object proximity stopped working. It comes up on the screen that there is a object near but no audible warning.
Harrie
Level 3:
Top Expert:
  • Cars & Trucks Master 6,746 Answers
  • Posted on Jan 03, 2015
 Harrie
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1284423
Points
83153
When it comes up the screen, the sensor part is working. It could be the buzzer is defect, or just the wiring or a connector to the busses or speaker is lose. Start checking the whole chain.
4 Related Answers
Anonymous
  • 100 Answers
  • Posted on Jan 19, 2009
SOURCE: 1995 Jeep Grand Cherokee seat belt noise and light.
Hi
There is a switch in the seat belt latch whe your sitting in the seat this will ba the part o the right side, see if something went into the latch part? or the switch is bad i think you have to replace the belt to fix the switch
RD
goalie39
Ed
  • 479 Answers
  • Posted on Apr 20, 2009
SOURCE: 99 new beetle- warning chimes not working
Have you checked the fuse box, it may be on an obscure circuit. check each and every fuse closely.
Hope this is of some help.
Anonymous
  • Posted on Jan 04, 2010
SOURCE: 2006 Saturn ION Warning chime does not work
you could have blown a fuse and check that and it could also be a broken wire there also but i would rec. to check the fuse first
Anonymous
  • 90 Answers
  • Posted on May 10, 2010
SOURCE: I have a Jeep Grand Cherokee, and recently the air
need to replace clock spring which is located under steering wheel airbag, if you are going to carry out repair disconnect battery and leave for at least 5 mins then you can strip down steering wheel safely without possible airbag going off, but you will need a steering wheel pulling tool and the rest is quite straight forward
1helpful
2answers
How do I disable seat belt chime in 2003 GMC Yukon it goes off while driving non stop. Please include pictures
There is no dinger as the other guy suggests . sound comes from the driver door speaker .
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. On vehicles with an audio amplifier, the amplifier instead of the radio generates the audible warnings and receives audible warnings requests via the class 2 serial data line. Either the radio or the audio amplifier is the chime producer. The following lists the audible warning priority and the pulse rate:
Fast rate chime (150 pulses per min)
Medium rate chime (100 pulses per min)
Slow rate chime (50 pulses per min)
Turn signal reminder (will pulse at turn signal flasher rate)
Your best bet ,wear your seatbelt . so the sound goes off . If you do wear the seat belt and the chime sounds ,have a qualified repair shop check it .
MY 08 HUMMER ALPHA OIL ALARM KEEPS ON BEEPING WHEN TURNING THE ENGINE ON FOR A WHILE THEN DRIVE IT. ALARM SHUTS OFF WHEN SPEED UP TO 75MPH. OIL PUMP AND OIL PRESSURE SENSOR HAS BEEN CHANGE ALREADY....
your best bet , take it to a qualified repair shop. Have it checked for DTC'S - diagnostic trouble code's
Audible Warnings Description and Operation
The audible warnings alert the driver of a system concern or a critical vehicle condition. The instrument panel cluster (IPC) generates audible warnings through an internal acoustic speaker. The IPC receives audible warning requests via the serial data circuit. If the IPC receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
Door Ajar Warning
The IPC activates the door ajar audible warning as requested by the body control module (BCM). The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The door ajar warning sounds and the appropriate DOOR AJAR indicator illuminates in the driver information center (DIC) when the following occurs:
• The body control module (BCM) determines that a door, driver door, passenger door. The IPC receives a serial data message from the BCM indicating the door ajar status.
• The vehicle is not in park. The IPC receives a serial data message from the BCM indicating the gear position.
• The vehicle speed is greater than 8.05 km/h (5 MPH). The IPC uses the vehicle speed information from the ECM to calculate the vehicle speed.
Fasten Safety Belt Warning
The IPC activates the fasten safety belt audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled. The IPC receives a serial data message from the SDM indicating the drivers seat belt status.
If the seat belt is buckled when the ignition is turned ON, the chime will not sound. If the seat belt is buckled while the chime is sounding, the chime will stop. If the seat belt is unbuckled after the initial transition to ON, the chime will not sound.
Key-In-Ignition Warning
The IPC activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open. The IPC receives a serial data message from the BCM indicating the door ajar status.
• The BCM determines that the key-in-ignition switch is closed and the signal circuit is low. The IPC receives a serial data message from the BCM indicating the key-in-ignition status.
Lights On Warning
The IPC activates the lights on warning as requested by the body control module (BCM). The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The lights on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the drivers door is open and the signal circuit is low.
• The BCM determines that the headlamp switch is in the park or head position.
Park Brake Warning
The IPC activates the park brake audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration.
• The body control module (BCM) determines that the park brake is applied.
• The vehicle is not in park. The IPC receives a serial data message from the engine control module (ECM) indicating the gear position.
• The vehicle speed is greater than 8.05 km/h (5 mph). The IPC uses the vehicle speed signal information from the engine control module (ECM) in order to calculate the vehicle speed.
Additional Warnings
The following warnings have an associated instrument panel cluster (IPC) indicator or driver information center (DIC) message:
• Check Oil Level
The IPC activates the audible warning as requested by the BCM. The BCM sends a serial data message to the chime producer indicating the chime frequency and duration.
• Low Fuel
• Oil Pressure Low Stop Engine
• Reduced Engine Power
• Trans Hot Idle Engine
• Turn Signal On
How do we get a 2006 Uplander to stop chiming?
What is it chiming ? Chimes for different reasons , headlamps on , seat belt not buckled , etc.... What warning light is lit on the instrument cluster ? if any . seat belt , air bag's etc...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The following lists the audible warning priority and the pulse rate:
Single chime
The inflatable restraint sensing and diagnostic module (SDM) activates the fasten safety belt audible warning for 5-8 seconds. The fasten safety belt warning sounds and the fasten seat belt indicator illuminates when the following occurs:
• The ignition switch is in RUN, BULB TEST, or START position.
• The SDM detects that the driver's seat belt is not buckled (signal is low).
If the seat belt is buckled before the ignition is in RUN, BULB TEST, or START position, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops.
The instrument panel cluster (IPC) activates the key-in-ignition audible warning. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is in OFF, LOCK, or ACCY position.
• The body control module (BCM) determines that the driver's door is open (signal is low).
• The BCM determines that the key-in-ignition switch is closed (signal is low).
Lights On Warning
The instrument panel cluster (IPC) activates the lights on audible warning. The lights on warning sounds when the following occurs:
• The key is not in the ignition.
• The body control module (BCM) determines that the drivers door is open (signal is low).
Rear Parking Assist
The rear object sensor control module activates the audible warning. The audible warning sounds whenever any of the indicators are illuminated on the rear parking assist display. For a description of the rear parking assist system refer to Object Detection Description and Operation.
Turn Signal Reminder
The instrument panel cluster (IPC) sounds the turn signal reminder once per each flash of the turn signal lamps when:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit (left or right turn).
• The vehicle has traveled a distance of 1.2 km (0.75 mi) by counting pulses on the vehicle speed input circuit.
The IPC turns off the turn signal reminder when either the ignition switch is turned to the LOCK position or to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits (left turn or right turn).
Additional Chimes
The following chimes will turn on when an associated indicator turns on in the instrument panel cluster (IPC):
• Low Fuel Indicator
• Low Oil Pressure Indicator
• OVER SPEED indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation.
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console.
Your have a problem with one of these systems , your best bet , take it to a qualified repair shop. They would do diagnostic's to find the problem .
Do any indicators illuminate when the chime sounds?
Go to Symptoms - Instrument Panel, Gages and Console
Go to Step 3
Turn the ignition OFF.
Remove the key from the ignition.
Turn the headlamp switch to OFF.
Close all of the vehicle doors.
Open one or more of the vehicle doors
Does the chime sound at all times regardless if the doors are open or closed?
Go to Step 15
Go to Step 4
With a scan tool, observe the LF Door Ajar Switch parameter and the RF Door Ajar Switch parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Door Ajar Switch parameters display Door Closed?
With a scan tool, observe the Left Rear Door Ajar Sw. parameter and the Right Rear Door Sw. parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Rear Door Switch parameters display Closed?
This is a 21 step diagnostic trouble shooting flow chart .
2helpful
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Single chime
I'm installing a aftermarket stereo in my 2005 grand am se the wire harness adapter for my car requires I run the accessory wire to one of my fuses for whatever reason I need to know which one thanks
Are you aware of the fact that your factory radio is connected to the class 2 serial data communication network . You need a interface module to hook up to aftermarket radios . If you don't use this interface module your vehicle will not start an run an the warning chimes will not work .
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
3answers
What does it mean when the notifaction light comes on in a 2012 Jeep Grand Cherokee?
it means open glove and read the opr guide
and means read the warning page. all cars made and for sure 2012
RTM then ask.
it will show all lamps and stated what to do. is this hard?
How do I disconnect the warning chime?
Key in ignition chime ?
Saturn L-Series ?????? L what ? L100 ,L200 , L300
Audible Warnings
The body control module (BCM) will provide an audible warning for various events relating to the vehicle. The functions that provide an audible warning are the key in ignition, the lights on, the occupant restraint (seat belt) and the park brake.
Key in the Ignition Audible Chime
The BCM will provide an audible chime if the key is left in the ignition in either OFF or the accessory position with the driver's door open. The chime rate for this is 150 chimes per minute. The key in the ignition chime has a higher priority than the lights on chime.
Lights on Audible Chime
The BCM will provide an audible chime if the park lights are on and the driver's door is open. In addition, 1 or 2 other conditions exist. The key is out of the ignition, or the key is in the ignition in the OFF position, and has not been turned. The BCM will chime at a rate of 200 chimes per minute until the conditions are removed.
Occupant Restraint Audible Chime
The BCM will provide an audible chime based on the class II message received from the SDM if the driver's seat belt is not buckled when the ignition is turned to run or crank. The chime rate for this feature is 50 chimes per minute.
Park Brake Audible Chime
The BCM will provide an audible chime for park brake when the park brake is applied and the vehicle speed is higher that 3 mph. The chime rate for this feature is 200 chimes per minute.
You can't disconnect anything . The problem has to be fixed .
Audible Warnings (Chime)
Chime Rate Per Minute
150
200
Occupant (Seat Belt) Restraint Audible Chime
50
200
Content Theft Pre-Alarm Audible Chime
200
Telltale Chimes
The body control module (BCM) will provide 4 chimes for each telltale activation per ignition cycle, at a rate of 150 or 200 chimes per minute. The chimes are limited to 1 chime event per telltale for each ignition cycle. The power up telltale function will not activate the telltale chime function. If the telltale becomes active during a cycle then the chime will sound.
The following telltales will activate the chime function:
• Low Washer Fluid
• Change Oil Soon Indicator
• Brake Fluid Low
• Oil Pressure Low
• Coolant Temperature Hot
• Low Coolant Level
• Low Fuel Level
• Antilock Brake System
• Volts Light (Generator)
• Supplemental Inflatable Restraint System (Air Bag)
• Trunk or Hatch Ajar
Having the vehicle checked for DTC'S - diagnostic trouble code's in the BCM would be the first step in the diagnostic procedure .
DTC B2965
When the ignition key is seated in the ignition switch, the key-in-ignition switch contacts the close, grounding circuit 80. The body control module (BCM) monitors the state of the key-in-ignition switch, the state of the ignition switch (OFF, ACC, or RUN) and the driver's door to control the key-in-ignition chime.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
