Cell Phones Logo
Kelyn Cochran Posted on Jan 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reboot my galaxys from black screen
Phone is stuck on black screen mode. it powers on but wont show anything else other than the black screen. the home buttons on bottom light up but wont take it anywhere else
Romeo Direzze
Level 2:
Habit-Forming:
New Friend:
  • Expert 58 Answers
  • Posted on Jan 03, 2015
Romeo Direzze
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
58
Questions
0
Helped
23633
Points
178
Run a Hardware Factory Reset A hardware factory reset should be used as a last resort to fix a GS4 . The process will delete all stored information on the GS4 and return the device to its factory configuration; you won't be able to back up your data if you're getting the BSOD. Prepare the phone for the hardware factory reset process by performing a battery reset and pulling out the memory card. You can remove the back panel by pulling on the indentation near the power button. You can leave the SIM card in the device. After you've closed the device, plug it into the charger to avoid losing power during the reset process. To initiate the recovery menu, boot the GS4 by holding the "Volume Up," "Home" and "Power" keys. On the "Recovery" menu, use the volume keys to select "Wipe Data/Factory Reset." Then press the "Power" key to initiate the hardware factory reset.
5 Related Answers
xedcom
Ed Perez
  • 127 Answers
  • Posted on Oct 12, 2007
SOURCE: phone screen is black
With the phone off, hold * and # keys and then press power button:
- If your phone screen still dont show anything then the backlight or whole screen is broken and you would need to replace or make a technician to replace the screen.
- If your phone shows a boot screen with serial numbers on it, then you would need to re-flash or reload the phone firmware to recover your phone. For that you may need some special software, a PC and your phone's USB cable. You can find tutorials and guides over the web.
To get out the bootloader screen you need to take out the battery and the re-flash procedure delete all your data so I recomend you to download it with your phones PC software.
Good Luck...
Anonymous
  • 7752 Answers
  • Posted on Dec 27, 2008
SOURCE: Phone wont finish powering on - stays on 1st rumor screen
golf - the firmware needs to be flash on teh phone so take it to amobile service center and have that done.
may - the phone needs to be reflash on the phone
Anonymous
  • 10 Answers
  • Posted on Mar 14, 2010
SOURCE: the scren on my lg neon is black wont show anything
call ur wireless provider and get tech support explain whats happening they'll get u a soulution or a refurbished lg neon
seofelite
Jonathan
  • 114 Answers
  • Posted on Jun 30, 2010
SOURCE: My Samsung Reclaim's Screen keeps going black!
Sounds like the motherboard is damaged. Take it to Samsung's technical support team, they'll be able to fix this for you.
destom
destom
  • 126 Answers
  • Posted on Mar 11, 2011
SOURCE: My new Samsung Galaxy Tab
Most tablets have a force shutdown, this is normally as simple as holding the power button for up to 30 seconds or pulling out the battery
How do I unbrick my phone?
    1. To wipe your data and cache:
      1. Power down your phone. Turn it back on and boot into Recovery mode. ...
      2. Use your volume keys to navigate the menus, and your power button to select menu items. Scroll down to Advanced, and choose "Wipe Dalvik Cache". ...
      3. Reboot your phone.
      How Do I Fix My Bricked Android Phone? - Lifehacker
      lifehacker.com/.../how-do-i-fix-my-bricked-android-phone Lifehacker
    Feedback
  1. How to Unbrick your Android Device ' The Ultimate Guide ...
    rootmyandroid.org > Featured
    Aug 25, 2014 - By my personal experience 90% of the people with bricked android ...My device is Bricked ! :( " ? ... Download the stock firmware of your phone.
    Unbrick - android-roms - Google Code
Dec 25, 2015 • Cell Phones
My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
Also, try booting to safe mode to test the power button:
  1. Turn "OFF" the Galaxy S6
  2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
  3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
  4. Keep holding the Volume Down until your phone finishes rebooting
  5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
  6. Let go of the Volume Down button
  7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
3answers
I cant get my phone out of safe mode and when I want to hold the power button for options like power off or restart it goes straight which means I cant follow the instructions on how to exit safe mode...
When you hold the button down to get to the power off window, keep holding the button down til the screen goes black and it reboots. If that doesn't work, try taking your battery and sim card out of your phone , put them back in and turn phone on......
Can Dream spammer, formerly FIFO and Jerry Smith, be removed from FIXYA? what should i do if i forgot my pin?
This is an Android tablet and you can try to reset it but this will erase all your personal data.
You can do this from the Android System Recovery menu.
To go in the Android system recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
When you are in the Android system recovery menu, use The Volume Up/Down keys for navigation and the Power button for confirmation.
Choose one by one:
- wipe data / factory reset
- Yes -- delete all user data
- reboot system now
9helpful
3answers
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
32helpful
2answers
The screen has frozen in e mail and i cannot switch off or move to another function or do anything
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
8helpful
2answers
My samsung gte 2120 wont start all it does is showing the welcome screen and restarts again
my samsung gte 2120 wont start all it does is showing the welcome screen and restarts again
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
