Ok my daughter has a alldaymall 7" 8GB tablet model:a88 she set a pattern for password and now doesn't remember the pattern and there's no reset button any suggestions on how to reset would be awesome
Isn't this the same problem as this one?
http://www.fixya.com/support/t24390784-pin_no_set_in_error_tablet_now_access
The tablet has no PIN. It is the SIM card for 3G that needs a PIN to access the 3G service.
When you remove the SIM card, the tablet will work perfectly without asking a PIN.
I hope this helps.
After a few attempts to guess pattern it should prompt for the gmail account assigned to the phone. Then allow a pattern reset and confirm.
SOURCE: Hi...my goibii 7inch tablet is locked with a
look for your tablet on the internet and find the lock overide sequence keys
SOURCE: how do i reset my hkc tablet model number p771a
This should do the trick,
1)Make sure the tablet is NOT connected to the charger
2) Power off the tablet by holding down the power button for about 10 seconds
3) Once it is off, hold down the HOME button and connect the charger while the button's being held down.
4) When you see the HKC logo come up, let go of the HOME button.
5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5.
6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again.
7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button.
8) Navigate to "Yes - delete all user data" and select it.
9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
Dave
