It searching for wi-fi networks it used to work but now isn't
SOURCE: wireless internet access
A wireless 802.11b LAN adapter is included in you tablet, activate it thru Control Panel / Wireless. Unfortunately this is the first generation standard and as such is extremely slow, has very limited range and is no longer supported by a lot of the newer generation devices/hotpoints.
SOURCE: screen reads unable to connect
Try this and see if this helps. Go into your network settings and press the little blue button to the right to see the network options you should see it already has a dns server and ip adress. Where it says auto join turn this off. Now see if you are able to connect. hope this helps kidromulous
SOURCE: I can't get wi-fi connectiion
Welcome to Fixya
First, make sure that WiFi is enabled on the Cruz Reader. From the Home Screen, select Wi-Fi Settings and ensure that both Wi-Fi and Network Notification are enabled with green check marks. After your unit search for network, your Wi-Fi networks list should populate. If you need to rescan, tap Menu> then tap Scan.Detected networks will appear with a SSID to the left, a status line beneath the SSID, a signal strength icon to the right. Those that are secure will also feature a padlock. Tap the network you wish to connect to, then click Connect. If a password is required, tap the text field for the popup keyboard. If you need to configure a connection manually, choose Add Wi-Fi Network> enter your router's SSID> select security type if any and enter password> and Save. Once the Cruz has successfully connected to any SSID, it is saved. When that SSID is no longer available, it is listed in the Wi-Fi networks list as "Not in range, remembered" in the status line.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: hi i have a pandigital novel book tablet
Please go to the Pandigital website and update the firmware, I will attach a link below.
Thanks for using FixYa
http://www.pandigital.net/Downloads
